Hi guys,
I am very worried, i have had my car in for a long over due 7 weeks ( ment to be 2) in a panel beater and i got it back yesturday, the guy told me it will run a little ruff because it has only been start and driven 5 metres and stopped for 7 weeks. It is alot worse than a little ruff!
The car idle is very ruff and cuts out when stopping. the car is blowing alot of dark black smoke. and when i hit turbo the car has a flat spot that last for ever and the car shudders if trying to accelerate but can't and poors out black smoke.
I have a apexi pfc had ben taken out and on the floor and avcr which the boost was on hi after i left it off. My car is out of rego cause they took so bloody long and i can't get a pink slip while my car is like this.
Guys i am very worried.
They could have even put standard fuel in it. Would this cause these problems?
The car will not turn over today could this be damage spark plugs due to the 7 weeks of hell it was put through.
Can anyone help me out?
https://www.sau.com.au/forums/topic/139616-panel-beaters-stuffed-my-car-help/
hey mate,
few options here,
what was the original reason the car was at ythe panel beaters? if it has takin a hit you may be looking at things like a smashed afm, leaking cooler pipes etc.
option two is if they have washed the engine bay down after work and the plugs now have water in them.
start by checking things like plugs and that the afm is actually plugged in.
the excissive black smoke says the engine doesnt know how much air is entering or that it isnt being ignited in the cylinder.
see how you go
gc
Dont stress too soon. Mine wasnt much better. Billowed smoke out the exhaust as well. Just change the plugs, put some good fuel in it and dump the oil (it can get a fair wack of condensation in it doing cold starts all the time) ... and take it from there
check if the AFM plug is in properly..
if it's not connected properly the ECU will go into failsafe mode, not allowing you to rev is more than 3500rpm and cause the motor to run excessive rich
Mine did the same also..
Massive amounts of black smoke.. wanted to stall etc..
Appeared to come good then later discovered they hadn't reconnected the carbon canistor so I had a massive vacuum leak. I doubt that would have been related as a vacuum leak has it running leaner. But none the less..
Also ran out of fuel driving to the closest petrol station, later found out they ran up close to 100km's in it. :(
with all my experiments with the afm e.g mesh take out, how ecu copes with free flow etc etc it sounds to me ur afm is gone.... it stutters at acceleration as if its struggles to climb revs.. at idle it'd blow black smoke, going from 0.5 to 1.5 ( depends ) blowing huge black smoke, ..overall its CRAP
if so dats ur afm man but check vac leaks n all just incase but yeah clean it with some wd40 the afm, and da ensor inside especially n see wat happens!
cheers
panel beaters..scares me to put my car in
Check your plugs! I reckon thats what ya problem will be.
A mate couldnt get his car to turn over after been at panel beaters, changed all sorts of things, didnt fix it, changed the plugs and bang, problem solved!
the wrong AFM setting in the powerFC will do this - a f**ked afm will do it also.
Why did the powerfc need to be removed?
Also, make sure your AAC valve is connected properly - thats another thing that will kill idle and blow black smoke.
Can't think of anything else. The 02 sensor has nothing to do with it - Mine is turned off, and My car runs perfectly.
If those assholes took it for a joyride, I'd be taking a few 0's off the bill.
Edited by The Mafia
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
