Yeah i reckon we should get on the piss in airle only problem is getting everybody to line up with rosters and that, for those who aren't on Monday to Friday. But it should be more like April, may a lot nicer weather not as hot either and all the rain should have pissed of by then. I also wouldn't mind going up to t'ville as well but don't no how bad the cops are there.
anzac/easter long weekend would be good. would be able to get a heap more people to come. weather will still be good, accomadation maybe dearer but we can always stay @ a caravan park/backpackers.
nur33- i would be more worried about the state of the roads on the way up.
You've got a point Benny, I forgot about Rosters... We'll have to check with everyone and see if anyone's rosters line up with weekends. The more people we get, the better it will be (Obviously, haha). Hopefully by then, Skitz' 33 is running fine and he can come up in his car. A T'ville cruise would be good too... Go and watch a footy game with the boys. I'm keen to do this if everyone else is serious. :)
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
