Sweet as. Started editing some RAW photos yet?
Can make them look really good with just the initial processing in photoshop.
Post some up if you edit some :)
Like I said to you, I really wish we got more photos but that's just the way it went lol.
Yeah I have to get my FC Hako working again. The latest firmware seems to have screwed something out and it's dropping out. Was gonna have a look at everything at the drags but it kept dropping out early in the run
Got a thread uo in the for sale section but thought i'd throw it in here as a local sale wold be alot easier lol..
18x9.5 +20 BBS RG-R wheels
R34 GTR Brembo Brakes
PM for details
Cheers
Matt
Mmmmmm Brembo's haha
You gonna get your photo DVD from airlie? :P
That goes for all who were there to
Well have the Wideband in now:
Seems a little laggy (not to bad, half a second probably tops) but I dont know if it gets better as it gets hotter or if the gauge is just slow. The main point is the analog out from the gauge to run with FC-Edit so I can bring up the AFR's on the laptop and in map watch. Should make tuning alot nicer
Pacey: You might know this... Is there a way to bring up two map watches in FC Edit? I want to have AFR and Knock maps both up, but I dont think its possible......
Had a play yesturday but didnt really get anywhere.
This looks like much more then 2 degrees of camber........
Used some Turtlewax bug and tar remover on my rear pods to get all the tar off that the tires flick up. Works a treat that stuff
Edited by 89CAL
Lol looks closer to 5!
Yeah I think pedders may have dropped the ball on that one. My report said 2.1 degrees or something.... Doesnt look right lol.
Did a little playing around with my tune today. Trying to fix a funny spot. 5th gear foot down and it goes 13.2 then climbs to 14ish then back down, weird. Added some fuel to a cell that looked like it might be the problem but its still doing it so not sure what the go Is....
So got my new front cover for my turbo made up......
The thing sounds even louder then before! I thought without the anti surge slots would make it alot quieter.
Anyway the thing is so rich now I'm lighting up the night with backfires so will need to play with the tune on the weekend (10:1 AFR's atm)
Wheelspin in second easily now but, if it wheelspins in 3rd after tuning then I may have solved the problem with the HKS GT2835 KAI and its disapointing results in comparison with the Pro S
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
