Anytime man. I need an excuse to go take some pics. Just let me know when so I can work out a good spot to shoot your car. Should be alright. It's much harder to shoot mine cause it really needs to be shot in a dark place, white cars are a bit easier :)
Lol all them parts cost me a lot of money back in the day and that was when the Yen was 105 to our dollar and it was still expensive as shit.
Genuine Abflug Carbon Rear Diffuser i want $700 for it, cost me over $1500 back in the day.
Genuine Autoselect Carbon Chibi Devil Wing i want $650, cost me $850.
Genuine Series 3 Xenon Lights Brand New i want $2000 they are worth over $3000 if you had to get them from Nissan, will fit GTST's as far as i know.
R34 N1 Nur RB26, has done 25,000kms Bare engine, no turbo or intake PM me for more specs on engine $9000.
OS Giken Triple Plate Clutch still in very good condition with push, pull converter $2000 worth over $3500 New.
Heaps of other shit to come
Ben, are you selling your turbos? What are they? How many kms, etc?
Yeah Jono was gonna try sell them as a kit Tomei Expreme Manifolds, HKS 2530's with HKS 1.3Bar Wastegates, and HKS Dump Pipes. all have been Ceremic Coated in Chrome and have not been used since they were done. They have done approx 15,000Kms. Asking $3200 for the lot.
Also have a Full Titanium Exhaust System as well.
-Sunline Racing GT Spec Titanium Front Pipe BRAND NEW Never Been Used - $1200 is I Payed Way more rolleyes.gif
-Greddy 90mm Titanium Catback Straight Through Used but in very good condition - $1000
do it phil!
looks good cal. phil i think you should start the carbon whore group :3some:
does anyone else think its time the mods just merged the mackay & townsville threads into a nth qld thread?
I have heaps of other shit for sale i pretty much want everything sold off the car so it is just a rolling chassis, my brother and I want to start another project car. After all the stuff we learnt building the R32 we think we can built a top level time attack car which will be more extreme than the R32 in nearly every way and will probably take another 3 years to do. So everything thing must go.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
