Hey boys, going to pick up my rims today and placing an order for tyres. Just wondering who you would trust with your rims to get fitted, i'm going for a stretched look on 20's and i really don't feel like picking them up with dents or marks or anything on my brand spankers. Thanks
Pretty tough R32 GTR just came past my work, was sort of a gun metal grey/matte black in colour. Had a GTR front bar and the turbo sounded so good. Heard it take off from up the road and come past, nearly jizzed.
So many tunes to do this week for Matsuri...! Who's going? Should be a good day.
If you aren't aware of the drift track just outside of mackay (About 50 mins away) - http://www.facebook.com/mackaydrift
Huge drift meet This saturday and sunday (22nd and 23rd).
Yeah 8sec pass is in the bag, which is pretty freaking awesome, ran a time of 8.97 @150mph and a 1.35 sec 60ft
. Believe it or not but this puts us 0.02 sec off Theo's world record for fastest H-pattern street tyred GTR, only a bee's dick in it. The car was re-dynoed at Godzilla Motorsport before the Jambo making 900rwhp on 30psi and the gear vs speed was setup so in 4th gear it was running approx 33psi. Had the car weighed as well and came in at 1440kg with half tank of fuel, bit heavy but has all steel panels still.
On the next run the boost was pumped up to approx 35-36psi which was probably close to 1000rwhp and launched the car, it was 3mph up by half track then 3rd gear decided to let go :( $$$$ oh well no world record this year. But hoping to smash it to bits once the gearbox is rebuilt. Can only get faster from now on considering there is approx 100kg + we can loose and it still has more power in the engine. Looking forward to next years Jambo f**k yeah.
f**k yeah
Was it an OS Giken gear set, seem to remember something like that. Where to from there?
Must be slightly disappointing. So close to the record its redicuolous lol. But I guess at that power/speed it doesn't take much.
Nah it was PPG Dogbox strongest box on the market but not Hipo GTR proof, where to from here probably strip the gearbox and see how much damage has been done it will be cheaper to rebuild it rather change setup then have another crack at the record.
That's right. I knew it was one of the top ones (would have to be lol)
Hopefully its not to bad then. Won't be real fun if your rebuilding gearboxes after every few runs
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
