Dan, you should most definitely fit one of these to something
http://www.bulletpro...ford%206.0l.htm
http://performancetruckproducts.com/772441-5001s-garrett-powermax-turbo-04-07-6-0l
and change the rear housing to be something decent at same time.... as Variable Nozzle Tech..............
Edited by Force Fed
Callan / Elite Racing
When I cc'd my R33 RB25 head I got 62ccs (It was shaved 20 thou)
Is your head a R34 Neo Head Callan? I think I read somewhere on this forum that the R34 Neos are around the 50cc mark?
Anyone able to shed some light on this? Having an issue with my new power FC looking as though it is cutting to the idle map during gear changes and then taking 2 secs or so to realise I'm at WOT.
Red Circle is a gear change where it looks like its going back to closed loop idle map then jumps up to normal timing.
Blue Circle is normal, no timing drop and doing what it should be doing
White Circle is another gear change where it is dropping timing then jumping up
Thought it was worth a try in here as well. TPS is at 0.45v closed and 4.15v at WOT
Anyone ever had experience with Boost Motorsport? I've been told they used to do a lot of work on imports when they first opened and are good. Might get them to do my gearbox change for me in a month if they get repped decent..
Can't Leon do it?
There used to be all this rage about Boost Motorsport, but I never actually heard anything good or bad, or now that I think about it anything about any work they did. I didn't think they were in existance anymore
Can't Leon do it?
Not sure haven't asked him yet, don't know if he'd be up for it. Already been told don't go near them aha..
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
