yeah well he has a 3mm one like the previous one i had on his 4ag and it was the heat/distortion/stress that prompted him to change mine...
rather some preventative maintenance before this shits in the car cos i would be slaaaaaack to change it in the car :yes:
Hmm i got a tuff decision, Do i make my own Dry Sump Pan or buy an ARE Cast one that bolts on easy as? I'm too slack to make my own but will save me more $$$ or just do an overtime at work to pay for it. FML :yucky:
Has anyone ever adjusted the std VCT inlet cam gear. I pulled mine off not realising it was slotted.
I dont really want to dial it in or anything like that cause it looks like a bit of a bitch to do (as the bolts are on the back). I've just got it about dead centre at the moment
Why did you undo the 3 locking bolts?
4 bolts. Because I didn't know they were slotted basically :)
Nah was gonna clean up the cam gear and vct cause they had a bit of surface rust. I've put it back so the washers cover up the slots so will probably be close enough
Ignore Chris, Callan. He likes boys...
If this were true, I wouldnt be waiting for my motor to be finished still :P
Cause it's about to go on a pallet motherf**ker.
So............... you like boys?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
