So I'm selling Both of my new Apexi Power FC's, have got a response from the Apexi engineers and they say its my tune, but I've used the base map and played around with the timing in these areas with no results
So If anyone knows someone after an R33 GTST Apexi Power FC. I have 2 brand new ones. STATUS and others said they have had no troubles with these so it may just be an issue with my car, but I'm not really willing to chase it if they arent going to offer support.
Chasing $1100 for each Power FC. They are both the latest models, come with everything in box including new EL hand controllers.
Looks like I'm getting a link
Nah nothing to crazy, sensible car
just getting an A4, hopefully with an S-line kit and decent mags on it. Probably the only thing I'd touch would be the wheels. Park the Skyline most of the time, drive something that doesnt chew fuel and will be practical later in life. Thinking ahead and all that.
Should be sweet anyway. Bit nicer then a commodore
anyone know who stocks Motul 300v chrono 10w40 engine oil locally? tried calling autobarn but they were busy so i'll duck in there after work just wanting to know if anyone knew for sure a shop that has it in town.
cheers
I prefer Castrol edge engine oil over the Motul Oil. Castrol edge can cop a fair bit of punishment, tried and tested in our GTR and a lot of sport compact drag cars use it as well. Motul oil is very over priced.
I have Castrol edge in mine, honestly there isn't that much difference between them all. I perfer the Motul, it seems a bit nicer (quieter) with it, but at the end of the day most of the higher end mainstream oils will do the job.
I changed from Motul puerly to make life easier for me. I was having to order oil every time, where as going down to supercheap and grabbing a bottle of Castrol is much easier
I'm trying to get some info on Link + Link accessories but not having much luck with it. So far because I'm not that desperate for it I have just been emailing some Australian dealers and have emailed Link ECU direct. Link ECU gave me the closest dealer to me (Townsville) which I already knew but fair enough they are doing there job. At the moment I'm trying to find the info I need, I think I need the expansion cable to run the IAT sensor (as it uses an extra input) so basically I just want to know this and if they supply boost solenoids.
Also, My Power FC's are still for sale :)
Fault is with my car not the unit itself for those playing at home
Edited by 89CAL
That's the plan. Finally heard back from someone about getting one. Just gotta add a 4 bar map sensor and boost solenoid and should be a done deal.
Is there any setup for the knock control? I can see you can minister individual cylinders but I'm hoping it uses the stock sensors without to.much stuffing around. Haven't looked at the pin outs for the knock sensors might do that later
Vct setup looks easy, boost looks a bit harder to setup but probably just a matter of playing around with it. Hopefully won't be to hard to tune. Doesn't look to bad just alot more setup then the power fc
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
