what about a T78-33D? or are they borderline BFOT?
I'd say a T78 is pretty much BFOT territory, similar to T04Z - and aren't you trying to get around that?
If you're looking down the Trust path, TD-07S is smaller.
So is it still SST, or are you thinking of something a bit larger?
I would like to see the results of an HKS T04Z with the .61 rear used on a standard displacement RB26 ;)
would go quite well no doubt.
I was running 3037s56t on rb25, it was nuts, made well over 300rwkw, made strong boost under 4k rpm - and not one garrett name brand came anywhere near the sort of response/power I was making - infact I have never seen a garrett generic turbo make near the same power/response/toque/spool as the HKS did. (but that is a different topic.
On RB26, no doubt the 3037 would be a very sweet thing indeed.
for the twin set-up I want I'd need:
HKS 2530s
for SST
HKS 3037
Not a good comparison, 2530's would get you up around 400 rwkw (not 300 rwkw). I think 2510's would be a better choice if 300 rwkw is your target. But having driven several GTR's with 2530's they would be my choice with around 350 4wkw. They make a NICE circuit car, perhaps why the Mines R34GTR has 2530's on it, as does the re-released Nismo R32 Ztune.
;) cheers :D
You haven't looked hard enough, GCG supplied GT3040 = 325 rwkw with 1 bar at 3,750 rpm. It's all in the tuning, spend $200 extra on that and save $1K on the turbo
;) cheers :D
700HP-GTR33 I certainly hope you're kidding around because thats a ridiculous suggestion that unless they have 2 turbos, a GTR is not a GTR!!
Have a look next track day and see how (especially a certain) big single GTRs go. The days of useless BFOTs has passed, there is absolutely no reason a single can't do what twins do.
Back on topic T78 is way too BFOT, T04Z is awesome in comparison, 500rwhp @ 19psi with delivery by 4500rpm not being strictly on/off either, with the .81 rear. I'd track back towards something like a GT3037, GT3040 for the lower power level.
yes, well my car was tuned at the same place other guys had their gt30s done - does this mean I could have had alot more than 321? most likely, a japanese mech seemed to think it was a bit low...
would love to see a dyno graph for this gt3040, sounds like it worked unusually well, as there was another guy on here who fitted one (gcg) and he hated the thing - ended up going hks 3040 and fell in love.
As Gary mentioned, for 300rwkw on a twin setup,you want the most efficient turbos you can find so you would either search for a set of HKS GT2510's, or for the newer option, GT-SS's.
Both will comfortably reach the power goal and its already a well known fact that for response, its hard to go past GT-SS's, especially at ~$3,000 for a complete kit (Half the cost of the proposed SST setup!)
Speaking of the GT-SS Turbo.
My friend just bought a turbo and was told it was HKS GT-SS turbo.
It only has Garrett written on the housing but I don't recall if HKS actually put their name on all HKS turbos?
The core has this written on it:
HJ 0188J
GT S
472560-14
Can anyone confirm? :)
Edited by GTR-Ben
thanks for the input. good to get the SAU brains trust on this one.
nick, you are right, HKS GT-SS are the proven option and very good value at $3K, but you do need to factor in twin dumps and front pipes which would be much cheaper on the SST set-up with just one simple dump, and one simple front pipe.
Gary, I hear you on the 2530s too. They would be my other choice I think.
Morgs, I will heed that advice and put the T78 in the BFOT bag. but definately considering one of the small T04Zs.
What housing A/Rs do they come in (both ex and comp).
Something around .81 rear and a .60 front could be good depending on physical size/wheel size/trim. Should be good for 350rwkw and hopefully full boost before 4000rpm. basically whatever turbo I end up with I'd want the wastegate (s) cracked open before 4000. otherwise it's not really going to do it for me on street or track for that matter.
I would like to see the results of an HKS T04Z with the .61 rear used on a standard displacement RB26 :)
Speak to Dave (T04GTR) about his
Its a bit laggy, but the top end is quite a rush
Someone lock this thread....too may good ideas floating around.
Does anyone know the details of the IHI turbos the Z-Tune uses?
If its a track car, then i say stick with low mount twins and std manifolds and heat shields. Controlling the heat with a single and tubular manifold is a bitch on the track. And the heat from a little RB20 setup is going to be less then 300-330rwkws.
Agreed, Fernis cars is pretty damn impressive. I mean its pretty damn impressive :)
that is a good point. heat will definately be a problem. but damn we love the gate. and i know you do too.
Yeh new engine will have gate...though with the change to a smaller turbo and more displacement you might get too much gate and need to plumb it back :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
