Hey guyz,
i noticed that my climate control is behaving in a very "extreme" manner
when turned to 18degrees (the lowest) it becomes damn cold (@ 18 i presume) and when i increase the temp
to 19degrees it becomes damn hot...like it's at it's hottest...
an electrician told me that it could be my aircon server motor's fault and it requires 2hours of labour just to check it out ...anyone have any good recommendations on what to do?
chock
https://www.sau.com.au/forums/topic/140816-aircon-system/
Hey guyz,
chock
sounds like your mechanic wants to drain your pocket..
In most cases it's your in cabin temperature sensor. Borrow someone's and see if that fixes the problem.
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2624659
  • 5 weeks later...
I too am having problems with my climate control, it read -30deg for the ambient temp, thinking it was the unit itself that was dodgy I swapped for a spare I had and still reading -30deg. I'm thinking this might explain why I can't get the aircon to work, it just blows really hot air all the time as it thinks it's 30 degrees below zero in the car..
So where is this in-cabin temperature sensor located?
Cheers.
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2708745
I've had the same problem for ages, it will blow hot hot air at any temp setting. I just use the 'FC' function (hold down the cold button for 3 seconds at 18 degrees) on the aircon to get cold air when I need it..... stuff the climate control, I either want it hot, or cold, there is no inbetween :laugh:
If it starts to only blow hot air in any mode, then I'll have to do something about it.
Fixxxer
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2718950
to the right of the ashtray. a couple of little vent holes on the front of the panel and the sensor is mounted in behind.
Ohhh.. that thing I discovered when I put my stereo in that isn't connected.. I thought it may have been like a mic for an carphone system or something from japan.. pretty sure the wires have been chopped - guess I need to find a wiring diagram and start fishing around behind the dash :thumbsdow
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2720111
i had the same issues. i just removed the faulty sensor (Left side of dash, under windscreen) and replaced it with a resistor that is the right impedence, to make the climate control think that the intake temp is 30deg.
Edited by R324DR
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2720175
So when you turn the climate control on it just cranks the aircon?
Are replacement sensors hard/expensive to get?
Got any specs on the various sensors? says all of mine are shagged :P
Sory for all the questions.. my mrs wants the aircon working :P
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2722614
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
