Hey Kermit, I got you to do my exhaust before you had stickers made up. Any chance I can grab one from you now? Are you coming to the SAUWA cruise? I just want one to stick above my muffler :worship:
hey mate , of course you can have a sticker , i remember your car , it sounded soo hot lol.
was sposed to be coming to the cruise but unfortunately i have to attend a birthday party so will have to catch up another time.
kermit
  • Replies 353
Posted Images
hey kermit do you think you could make me up a side pipe for a r32 ,from the front pipe just out to the side for drift days, it doesnt have to be stainless im happy with mild steel, also how much $$$$$
i would be happy to put one of your stickers on my car aswell
cheers ty
hey ty , a stainless side pipe ( dont do mild steel ) is fine but due to cams regs has to exit just in front of the rear tyre. can happily make these up for $ 170 which will include a bracket to prevent rattling.
kermit 0422549050
just had my custome muffler made up today by kermit 3' to 2 2.5' tips and does it sound great and look great highly recomend kermit help this guy fund his drift ppl !!
actually its a 3" to custom twin 3" shotgun set up but yes it does sound awesome
kermit :)
hi kermit, could ya pm me with the cost of welding a couple of flanges onto my cat? heres what i need:
its a 3.5" cat (i bring this)
3" - 2 bolt one side
3.5" - 3 bolt other side
im gonna need afew 3.5" 3 bolt gaskets too if u got em :D
Hey Kermit,
I've got a system that is mounted way to low and because of that my middle muffler is a bit mushed, reckon there's much you could do about bring it up a bit higher, or would it just be better to get a full new system?
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
