Guest INASNT
Originally posted by EVOIV
INASNT: What car do you have? Guessing a Skyline R33? I think a 0.87 housing would be perfect for the RB25...not too laggy, and a heap of top end power.
yep RB25.
Guy with SR20 wants to get the 1.12 turbine housing and this is on a circuit car he is building!!!
  • Replies 283
Hmm...a 1.12 housing is going to be crazy lag :D I would rather go for the larger T51 HKS turbo instead of the GT3037S with 1.12A/R. I think it looks nicer ;) He using a stroker kit? 2.2L? Well, there is the white JUN s15 in Perth that's supposed to be a circuit car. And that runs a T88. Too big if you ask me :D
RS500 thanks for the link to the comparison chart. I see what you are saying about the turbine housing. Only confused now that once the wastegate opens, wouldnt back pressure be about the same at 1 bar of boost wether o.87 or 0.61???
I think HKS recommend the 0.87 turbine housing for RB25, but I will wait and see what this turbo goes like when I start winding boost in before I trade in the housing for a larger one. If I can keep a similar torque curve, its staying. Very nice to have good power available from low down, and it is definately more responsive and pulls alot harder off boost than with the stock turbo.
Paul, if the car is on the road, not getting work done, there is every chance in the world.
  • 2 months later...
question here guys. When I brought my car they told me it had a hks 2530 on it. When I pulled some of the plumbing off recently and got a better look at the turbo the only clues I got to it being aftermarket was the smooth feel of the ball bearing blades, and a small badge near the (oil?) feed line which said gt2530. Now is this turbo a garret? by the sounds of it it wont make alot of difference, garret seem to know their stuff...
HKS use garrett cores, the HKS 2530 is infact a HKS GT2530, and it should have a plate saying GT2530 on the core.
But, it should also have HKS on the compressor cover and turbine cover, as they have them specially made to their specs, as are the compressor wheels. This is what you pay the extra for.
The core though is identical.
  • 1 month later...
It will be interesting to see how the GT30 you are fitting goes in comparsion - hurry up:D
If your curious to know, my previous turbo was a gt30 (the previous owner told me it was a gt35/40). It had a .82 rear housing (it was a 500hp turbo). on 26psi it made 320+rwkw. It had full boost @ 4000rpm (320rwkw). It started spooling up @ approx 3000rpm. It held 300rwkw to 6500k then dropped off to 290rwkw @ 7300rpm.
My t88 makes full boost abit later but makes the same power using much lesser boost + timing and holds it all the way to 7400rpm.
H.
H.
Thats funny coz i remember gtst-vspec thread and he was making 300rwkw with on 18psi with a 500hp GT30.
What size was the comp on your gt30?
Steve, i have a hks 2540 and it only has hks on the exaust housing. not on the actuator, nor the compressor housing. can you prove that it is not a hks turbo because i really doubt it as is was sold to me by a very reliable contact. please be sure of your statements as the amount of bullshit on this board must be approaching the 50% level...
night, mic
night, mic
spot reserved for ownage... I'm eating, will post my reply in a few mins
night, mic
There really was no need for that last comment, all you manged to do is make yourself look like a dickhead.
Anyway.... So you want proof? You really want proof that you got ripped off and your "very reliable contact" sold you an incomplete HKS turbo or worse, a Garrett turbo with HKS exhaust housing?
How about this... I scanned in a page of my HKS Goodsmaster.
Firstly, the page:
And a zoom of the turbo pictured:
Notice the big and unmistakable "HKS" cast onto the compressor housing?
Notice the caption that labels it a GT2540?
HKS GT2540s don't come with HKS wastegate actuators. You have to buy them seperately, so I scanned in that page too:
It is possible to use your standard actuators with the HKS turbo, but not very commonly done.
So.... Is that proof enough for you?
Now what's this about the bullshit level of posts on here??? Perhaps what YOU think is bullshit, is actually correct, and the bullshit lies solely with you.
26GTS, ask yourself, how do you know you have a HKS turbo if it doesnt have HKS on it?
All the HKS turbos I have seen (admittedly not hundreds, but I have seen many) have, as Merli demonstrated (cant get much clearer than that;) cheers), HKS on the housings.
Perhaps if you really do think 50% of the info on here is bullshit, you shouldnt bother logging on, as you would be doing yourself a disservice.
Admittedly there is some dis-information, but I have certainly learnt alot from here, as I would think most people who have been loggin on for a while have.
Perhaps you could word your posts a little better, rather than just jumping in and making broad sweeping and unfair generalisations - makes for much friendlier forums:)
Uh guys, you might have noticed he has an RB20 or 25 powered car. Odds are on the fact he is using a single turbo setup, which probably has a T3 flange. All of the HKS 25xx series with the T3 flange DO NOT have the custom HKS compressor cover, but use a Garrett cover with the center machined out and an aluminium insert held in by 4 hex screws.
The only HKS markings on the T3 range are on the exhaust cover, and on the metal tag on the center catridge.
Standard actuators work fine with those turbos too, so no dire need to run a HKS actuator.
Just my 2 cents, no need to jump on the bandwagon and drill someone over this...
Hi guys I've got a RB25det (auto) and I want to make around the 200rwkw mark I was first looking at a HKS2530 to do this but like the idea of cheaper price (new) turbo and running less boost to hit that target power.
So what would be a good Garrett turbo to hit my goal?
I already have:
Wolf ECU (not in-stalled)
910 Fuel pump (not in-stalled)
Filter
Comeing soon:
Turbo back exhaust (Depending on Turbo)
FMIC (Depending on Turbo)
Auto Tranny cooler
Fuel Reg
Injectors
I'm not after a dyno queen I just want useable power and it must spool up quick, I'm after torque.
Useing standard internals I'm looking at running two different settings with the Wolf Low boost around the 170-180rwkw and high boost 200-210rwkw.
I was looking at this one do you think this will be ok or do you think it might be to big for what I'm after?
Garrett GT25R Ball Bearing Turbo:-
Rated 380hp
Spec's:-
0.64a/r Turbine Housing (5 bolt outlet)
0.70a/r Compressor Housing
Watercooler Centre
48 Trim Compressor Wheel (T04S)
48 lbs/min Comp Flow Max.
76 Trim Turbine Wheel
Integral Wastegate
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
