+++white Face Dials @ Bezels+++ Get In Now
this link is to the current status of the parcel containing the Cyberstork meters. The c**ts at customs have decided to have fun with our parcel and are scrutinizing every detail. Ontop of that, they have been very slack in returning our calls, but please bear with us, Kezza and I are doing our utmost to get this thing cleared ASAP!
http://tracking.post.japanpost.jp/service/...P&locale=en
the tracking # is EI698268461JP sent via "E.M.S. Postage" (supposed to be 3-day express but is turning into 3-weeks)
Thank you for your enduring patience in the matter,
Mike, Cyberstork/J-Style Inc."
It has been all sorted... the parcel has been cleared , i should get them in the next day or so!!
about f**kING time!
  • Replies 271
Posted Images
they're very easy to install guys.
Xixor, if you need help with the leds or any of it, feel free to give me a buzz.
Basically, you remove the dash face, remove the cluster surround, take the cluster off. It's about 3 screws from memory.
The front clear face of the cluster is just clipped in. once you hvae it out, you'll know how to remove it. just push the clip in with your finger nail.
The leds are easy. you just undo a few caps at the back of the cluster, and the leds are inside. Straight pull the old one out and put the new one in. just like changing a light bulb.
For the faces, just cut them out and slip them over the needle. DO NOT remove the needle, otherwise you'll f**k up the cluster.
Edited by MANWHORE
do they come with directions on how not to fk up the install lol ?? :stupid:
This will help when it comes to pulling apart the car as well...
R32:
http://www.cyberstork.com/cgi-bin/howto.cg...p;imgtp=skyline
R33:
http://www.cyberstork.com/cgi-bin/howto.cg...amp;imgtp=ecr33
Once my kit arrives, I'm gonna see how many LED's are needed, and place an order with this mob:
http://www.ledshoponline.com/automotive_dashboard_bulb.htm
The T5 LEDs (which Im pretty sure the skyline has in the dash) are only $2 each... And they are the new "Wide Angle" ones as quoted above... As per the first post, there is 8 LEDS in the dash... so you can buy your own LED kit for $16 + $9 Shipping :stupid:
Note - I only just looked this company up now... sorry to those guys who have purchased through the group buy. Im sure those ones will come with instructions and will be better quality led's anyway :yes:
yeah man.. The leds are easy to fit!!! just plug and play items... only you need to make sure they are in the correct way!! one of 2 ways, lol one way wont work and the other way will ... they have built in diod so they will not blow if in reverse polarity!
but yeah the led kits we have are in sets of 4.. unsure if you would need more.... wouldnt think so!!
Had a look through the site listed above... and yeah they are just normal leds aranged in formation so they will give the best light hey can , because they are not full wide angle leds! as much as they say they are!!!
As the ones who ordered through me will see, that they are bright as hell! I know, i hooked one up to check it out , and i was BLIND for about 15min, lol.... well not fully blind but i could see a full on black area in my vision for ages...
they are $$$ because they are alot more powerfull, and they even have to have a small heat sink built in. they make that much light!!! Dont worry the heat sink WILL take the unwanted heat and WONT cause any problem, still not as much heat as a normal globe would make anyhow!!!
I could go on and on about leds, my car has alot of them... lol!!
the reason you need WIDE angle leds for dial app is because you only have 30mm or so from the point of light o the back of the dial its self.. now if you have a copy of a wide angle led you will see when they are on one point that is very bringt and dull around it!!!!
the WIDE angle leds have close to 180' of light chucked out so an even light will be showen on the dials!
If you missed out on the hi power led kits, ar maybe want more, the first led on that page listed above would be the best that site can give !! The rest are no good !
Im in the midlle of making a set of led tail lights for the R32!! using stock tails so you dont have the bling look of the aftermarkit ones. And just to have something full custom! then ill sell them!!
hahahah and no im not just going to bung a led blobe in the back... lmao
Cool!
Xizor, let me know what turns up in the kit :)
Also, the stuff was coming via snail mail yeah? Just need to know when to look out for it ;)
hahahaha.... they will be ok when the dial plates are over them! lmao
you can always go hard core like me and have so much stuff that lights up that people call it the star ship enterprise!!!
yeah it should take about 3 days max! well maybe 4!
cheers dudes.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
