60/40 more a track car
have a 4x4 for a daily
ive been told re55s are the go is anyoune running them and can you buy them in diffrent compounds as in harder/softer
Edited by spirosky33
https://www.sau.com.au/forums/topic/142897-semi-slicks/#findComment-2663194
I personally think anything Dunlop are the best, but RE55s are cheaper and come up to temo quicker which is good for club sprints...bad if you want to do 10 more then 6 or so laps.
RE55s also dont seem to mind plenty of heat cycles. A friend that ran the Yokos on his GTR and another that runs them in the 944 Porsche series think that after a few heat cycles they are past their best, even though they may have plenty of trad left on them
https://www.sau.com.au/forums/topic/142897-semi-slicks/#findComment-2663467
The Dunlop DZ02G are the best semis I have used, the bridgestone re55 are also excellent.
I've tried a bunch of other ones but have always been disappointed in comparison to those two - yoko A032R, yoko A048r, toyo 888, falken rs04v, falken rt215, kumho 712, dunlop d01j, dunlop d98j, bridgestone re540s.
But any of them will be chewed up in 5000klm especially if you are running a bit of camber.
https://www.sau.com.au/forums/topic/142897-semi-slicks/#findComment-2663874
for 60/40 track/road use, you would probably be best off with a good road tyre designed to be used on the track sg:
Falken RT615 (treadware 200)
Federal 595RS (treadware 180)
These aren't as sticky as semi slicks but have stiffer sidewall construction than most normal road tyres.
These are the allround pick of semis. One of the cheapest, best and most common:
Bridgestone RE55S soft=WT, med=TT, hard=SR
Bridgestone RE540S soft=G, med=S, hard=R
others:
Dunlop DZ02G
Dunlop D01J
Yokohama A032R
Yokohama A048R
Kumho V70A
Toyo RA1
Toyo R888
https://www.sau.com.au/forums/topic/142897-semi-slicks/#findComment-2664474
somthing sticky but not going to be chewed awy in 5000ks?
Most / All true Semi Slicks will be all but worn within 5000kms
My advice is go for the Federal 595-RS's
I had not driven on anything but street tyres until I bought these, at a recent track day I noticed the difference in grip levels and overall confidence they gave over the old Bridgestone road tyres was massive!
Infact I dropped almost 3 seconds in Lap times.
I imagine a true semi slick would be another level up again and would be good for another second off my lap time, but the tread life they offer is not enough for me as I do not want to run 2 sets of rims.
You should comfortably acheive 15'000kms from the Federals.
https://www.sau.com.au/forums/topic/142897-semi-slicks/#findComment-2671935
RE55's are the best bang for buck I have used.
And I've tried DJO1, DZ02, RE540 and A048's as well.
Just have a set of R888's on my car now but I'm not expecting much from them to be honest (only have them because they were free).
The only tyres I'd buy however are RE55's (SR compound - which is all they'll have unless you specify otherwise)
https://www.sau.com.au/forums/topic/142897-semi-slicks/#findComment-2673540
I have used RE55S, great grip, but only got a bit over 1500kms out of them
I have also used RE540, better wear, a little less grip
I am currently running Federal 595RS, cheapest of the bunch, grip is very good, they are on my daily which sees a track at least once a month and have lasted for nearly 6 months now, and still have more than 1/2 tread left
Best bang for buck, especially for street driven car IMO
https://www.sau.com.au/forums/topic/142897-semi-slicks/#findComment-2674472
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
