  • Replies 251
rb25 auto awd - front driveshaft pulled for rwd dyno
249rwkw at 17/16psi 3rd gear
Garrett GT3076 700177-5015 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
60mm diameter 84-trim GT30 turbine and 76mm diameter 7/14 bladed compressor wheel in 56.9-trim
JDM S15 Silvia 450/480cc injectors
z32 afm, tomei head, 3" exhaust, remap
I used a Dynapack hub dyno, they read higher than DD - its not magically higher but enough to make a difference. I don't know what the difference is, the one I did 300kw on is thought of by a few (who are used to Dynapacks) consider it a heart breaker for hub dynos but still no DD style heart breaker.
I know this is probably annoying for you, honestly it was for me too and its all my fault - so sorry about this. I have never removed the PRV as I don't have some vacuum hose long enough to reach from the wastegate to the boost source... the PRV has been spliced into my old one since I got it. I went and grabbed some the other day and went to put it on for the dyno tune (which was booked at the last moment) and found it didn't fit. The result of that is the PRV keeps snapping open and closed and stuffing up the boost curve and makes it not a realistic representation :D
For what its worth, when the PRV settles down the boost holds very very stable - I am going to get some vacuum hose that suits and am being hassled into putting my car on a dyno day in a couple of weeks so may end up just giving in to that without the valve and seeing what that does to the curve. I'll post the boost plot from that :happy: I didn't even bother getting this one printed.
Its definitely going to make it build less, not more aggressively when I remove it - the curve will be more consistant. Strangely it doesn't seem to behave the way it appeared to on the dyno on the road.... Not sure what was up with that.
  • 2 months later...
just read through most of this thread, some very informative stuff in here!
seems there is not much love for the 3071 .82; is the 3076 .82 really that much better for someone chasing 260-270rwkw?
3076 .82 would be the way to go. you will get bored with 270rwkw. atleast with the 3076 you have some more power left in it.
my 3076 makes 335rwkw on e85.
Good to see this thread still going! I see it a lot when I am googleing.
how do some of u guys get over 300kw with only 17psi on 3076r? hmmmm
I made 314rwkw on 18psi with water methanol injection. Torque was 720nm from 3000rpm all the way to the limiter.
mods:
Garrett GT3076, 0.6 compressor cover, 0.63 rear housing
Powerfc (Tuned by me)
Water Methanol Injection
Standard Engine
Standard Manifolds
Front mount Intercooler
Big Exhaust
Nismo 555cc Injectors
Standard FPR
Nismo 275lph In tank pump
They aren't really that great. Better off with a GT3076 with a 0.63 rear.
I'll be keen to test that with the RB30.
what would be the difference in response though?
not with a 0.63 rear.
I have a like new 0.63 internal gate rear housing for sale if anybody wants it, and a dump pipe to cat to suit. I'm unloading it because I have a RB2530 and the 0.63 rear might be fun, but is a little too restrictive for the RB30s extra breathing.
Sale thread here:
http://www.skylinesaustralia.com/forums/Rb...ml#entry5264403
  • 6 months later...
i'm looking at buying one of these
700177-5007
gt3076R
external gate
front trim 56, .60 ar front surge slotted
.84 rear trim, .82 4 bolt rear
i have the option of the .60 or .70 front
is tthere going to be much difference?
my combination at the moment is a standard rb25det
Ive got a 6boost and plazmaman
was recently making 300rwkw on a standard exhaust manifold. 3076R.70 front. .82 rear internal gated
i
