In WA, you can get OZ super streets from wilkinson suspension or from Xspeed
I would doubt you can get a permit for any suspsension mods in WA - I tried to, at welshpool when my car passed the pits (coilovers and just about every adjustable arm you can fit on S13), but the inspector said they dont issue them for suspension, its either legal or not.
The Aus spec super streets retail for around $400 more than the japanese ones
Thanks for replies,
yeah I hate it when they do that...they passed you but don't issue a permit..huum if that is the case I might as well get the Jap version? why do they even produce OZ version then?
XSpeed and WA Suspensions are the WA distributors for Tein OZ Spec.
You may find that the reason you were picked at the pits is the adjustable arms. They dont like them. Some coilovers will pass the pits as long as the spring rate is not to high and they dont deem it too hard, and the bottom mount of the strut is not height adjustable e.g. D2 etc.
As it states in my original post, I DID PASS with all adjustable arms, except the lower control arms - this includes pillow ball tie rod ends front
and the coilvers were D2 (mistake buying them)
The condition of aftermarket parts, and the overall condition of the car, is the main thing - if your car is a dog, they will go over it with a fine tooth comb and pick on everything. If your car is very clean and well maintained, your usually fine - that's what I have found anyway.
afaik, the jap ones have the same spring rates as the aussie ones. Only difference is the claimed revalving by fulcrum to suit aussie roads. Physically, the only difference between them is the product codes. I've had my jap super streets for more than 6 mths now and can't complain at all. The ride is comfortable and firm and a few other members in here can back tht claim as they have the same.
Sorry, misread your post.
I am surprised though. Ive been over with Whiteline Adjustable arms on the rear and they knocked me back. Whiteline arms have the bushes, not rose joints so i thought would be ok, but guess not. Maybe i got an inspector having a bad day.
Sounds like it...
I did some checking, the shocks in the Oz superstreets are different to Jdm ones
They are assembled in aust, but fulcrum (so I have been told), and have all parts necessary to fully rebuild if needed.
the Jdm ones use different internal components, and are assembled in J-land
this is what I was told by a dealer over here in WA that sold the Japanese super streets, not the Australian ones
Sounds like it...
Re: Teins being assembled here in Oz is correct. Fulcrum do carry all parts needed to make them complete/rebuild/modify. The difference between Jap and Oz spec is mainly in the shock valving. Spring rates are the same (4kg (or 225lbs) front and rear)
4kg front and rear for Skylines?? Thats odd, would have thought it'd be higher considering my jap specs in an S13 are 6/5kg
S13's have a MacPherson strut front end, hence different movement and leverage ratios. So comparing spring rates with a double wishbone car is pointless.
:O Cheers :rofl:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
