Motor cranks but theres no spark, we tested the actuator it seems to be alright. Im gonna test the coilpacks right now.
the thing is when we pull the spark plugs out and ground on it on the block, crank the engine and the spark plug doesnt spark.
I checked the igniter, it seems to be alright.
also when we undo the plug it doesnt smell like fuel as been in there.
Could it be something that is cutting the fuel and ignition?
Is there something else im missing? Someone have a diagram of the connectors?
https://www.sau.com.au/forums/topic/143202-fresh-rebuild-no-spark-no-fuel/
got the plug for the igniter plugged into the loom at the back of the head properly, same with the injector loom and injector plugs...have you checked the line for fuel coming out while cranking, if not perhaps pump, maybe fuse gone?
Check fuses (under dash) and relays (in engine bay). Check that the 2 relays behind theECU are switching when IGN -> "ON".
You should be able to hear the fuel pump priming at the initial IGN -> "ON".
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
