Hi Guys,
I noticed by accident this afternoon that there seems to be a little oil or something like oil on the back of my clutch pedal. Got a bit on my toe so checked and it is on the back of the pedal, and the pedal stem...and only the clutch. Could this be leading to something bad?
Thanks,
JB :)
https://www.sau.com.au/forums/topic/143578-is-this-a-bad-sign/
Yep it's brake (clutch) fluid, clutch master cyl as stated.
agreed, this is definatly the problem, make sure you keep topping up the fluid until you get a new clutch master cylinder, otherwise you will find out the hard way like i did :P lol
prolly a leak from your clutch master cylinder the brake fluid will eat the paint
My bet is that this is the cause....get it fixed asap cause brake fluid can be nasty stuff and I'd hate to see what it does to interior carpet etc.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
