am i the first to notice?
9500RPM IS OFF DA TACHO BRO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hope its chipped or something? otherwise itd be hitting the limiter well before 9500
I'd say he's got one of these. Maybe two (one for each eye).
While looking for that pic, I stumbled across this... I thought it was pretty funny.
  • Replies 167
Posted Images
Last I heard the real problem hadn't been found as he was still trying to blame the turbo. The teflon in the oil galleries sounds like it'd be worth checking out. That stuff is seriously dodgy and if bbe knows so much about motors why is he even using it?
As for smoking Ceffys,how do you roll them and aren't they a bastard to light? :D
As for smoking Ceffys,how do you roll them and aren't they a bastard to light? :sick:
Not if you have NOS bro! Just shoot it up! :sick::P
As for friday night, smoking Ceffys... Hmm... Maybe smoking a bit too much weed, as, if I remember correctly, friday night, the car had no turbo... :sick:
Circular logic:
A healthy, finely tuned engine can run 9500 RPM.
My car can run 9500 RPM, threfore it is highly tuned and healthy!
It's like saying Dogs eat steak and run around a lot
I run around a lot and eat steak, therefore I am a dog!
Just a question to Slide,
Why would someone swap from a GCG highflow to one of your turbos? Isnt it a downgrade going from BB to TB?
To the guy from the thread. I remember when I installed my GCG, there were very strict instructions to do the following
- Check the oil/water lines when off the car (I used a pipe cleaner to clean it, then blew through them to be certain they were clean)
- Once turbo is on, before connecting the oil drain, crank the engine over until oil comes out the bottom, did that!
- Upon first installation, let the car idle for 10 minutes WITHOUT revving it to let the seals settle, did that!
- During the last 5 minutes of that 10 minutes, I ran it under some idle load (A/C on, lights on, music on etc)
- Checked for oil leaks, none!
THEN, ONLY THEN did I take the car out for a drive. You know what, Id never swapped a turbo before that, and guess what, my GCG have no problems what so ever.
Be smart, dont be arrogant.
He was mistaken...
I made recommended MTQ (Dynamic Turbochargers) for a SA based turbo company to another member as I know of one car that has been running around with a bush rb20t highflow for some years now and has had no problems.
bbe jumped in to the thread saying they were shit, he installed one and it stuffed up straight away.
In bbe's other thread he claimed it was a gcg highflow that he had, I made mention of that and he later said he made a mistake and it was MTQ..
If one had such a problem with a turbo and it wasn't covered under warranty I sure as hell know I wouldn't easily mistake them for another company that sound nothing like them. Especially GCG that isn't even in Adelaide. :laugh:
But thats just me, just fishy thats all.
He's not very clear communicating his thoughts, just rambles.
I saw an interesting bumper sticker today.
"Why is it those with closed minds always open their mouth"
Ummmmm
Not this topic again...
It seems he does not want to admit responcability. He said in his first thread that he had modified his oil line. Then in this thread he says that he only found out about the oil line modifications after fitting and destroying the turbo...
So which story is it... I suggest you didnt modify the oil feed correctlly or even at all... You may have modified it tho before returning it to slide...
As i have stated before Im not sticking up for a forum trader as i dont really know Arron well at all. I have never purchased from him. I probablly would tho if he had something i needed as he is local to me and has a very high trader rating. I think most would aggree that I am seen as an on-bias moderator by most of the forum. I still think that Arron is right and you my friend are wrong. But thanks for sharing with the forum it made for an interesting read and i learnt something new.
Thank You
Without wanting to spark up a Ball Bearing vs Journal Bearing debate again both turbo's perform exceptionally well and are both are great upgrades.
The cheaper option is journal bearing and for the same results is a great option for uprade over its ball bearing equivalent.
I am probably one of very few manufacturers of turbochargers that prefers the Journal highflows over Ball Bearing.
I cannot justify spending the money on a turbo to make 250-260rwkw at a cost of over the price of brand new Garrett Turbochargers such as the GT3040R etc
They are now available internally gated and are a great option for uprade for now and future performance expectations.
With such a small frame turbocharger the difference between ball bearing and journal is not something that is noticable to the point where it matters.
:P
Those pix that were posted slide. were pretty blurry..
BBE ur better off taking it up in person, not on this forum. as u get better results from people that way.
i am shocked at the moronic posts in this thread. the incident could be either of their faults, better to get it all checked out by a third party. with no affiliation to either party.
flame on.
Edited by silverbulletR33
i am shocked at the moronic posts in this thread. the incident could be either of their faults. and u know it, better to get it all checked out by a third party. with no affiliation to either party.
flame on morons.
They are not blurry enough to hide the fact that its extreme heat damage, which is only caused by lack of oil supply.
Nothing else :ninja:
So blurry or not, the failure reason is undisputable, along with the fact this isnt the first turbo BBE has killed... its pointing directly towards a motor/oil issue, not a turbo issue
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
