if it comes in the kit, then probably. make sure you check if the dump pipe mates up with the stock one.
but as soon as you fit, youll boost it up, hit r&r and then youll post up why your car runs like poo. so best you do some research on all of the mods you will to make it work correctly and get the best out of it.
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2680426
if it doesnt come with lines, you will have to make up new ones and a silicon elbow off the turbo to the intercooler pipes. Also depending on the size of the front cover you may need to make a new induction pipe...
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2681062
I already have everything nessary to run the turbo just wanted to no if it would fit with out to many problems so it shouldnt r+r as i dont have the stock computer and yes i know ill have to tune it just wanted to know about the fittment thats all
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2681108
Well in that case yes it will bolt straight on there, as my 3037 pro s did, the only thing you will have to worry about is the dump pipe/front pipe to cat position and most likely going to have to custom on, part from that good luck, i think thats the answer you were after?
and of course you do know that you have to change the lines part from that it does bolt on
Thankyou
adam
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2681485
Just wanted to know if a hks 2835 pro s will bolt straight up to a rb 25 ?
if you buy the kit!
it comes with everything you need.
also it doesnt need a gasket from the turbo to the dump, i went around in circle with hks tring to get one, 1st they sent me the wrong 2 gasket then in the end they finally said OHHH GT2835 PRO S that doesnt need a gasket at all ahah!
awsome turbo i see full boost under 3500rpm
umm mine come with all lines (braided), metal intake pipe, silicon thingso and also the elbow from the turbo to the i/c (also inc silccon thingo and i little clamp which has like a heatshield over the silicon joiner thingo) + a nice hks heat sheild
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2682062
' date='17 Nov 2006, 10:24 PM' post='2682062']
Mine doesnt really hit its swing till 4grand. what boost are you running? I think mine can see 19psi by 4grand, then falls to 16-17. Although you can really feel the torque coming on just after 3grand.
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2682972
im only running 16psi with a very very safe tune (11:1 afr)
i want to do headgasket and cams and increase the boost to the 18psi see if i can come close to 400rwhp
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2682985
As everyone else has said, they are a great turbo, Brought the kit. Straight bolt on with no problems what so ever. Have just fitted cams and Plazmaman plenum. Have to go an get a tune asap.
Edited by woolls
https://www.sau.com.au/forums/topic/143645-hks-2835-pro-s/#findComment-2683353
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
