Items:
RB30E or RB25DE (R32)
Extra Info:
30E can be everything bar the head, and the 25DE can be all the provisions for the head.
Contact Details:
0401 317 009 or [email protected] or PM me
Price and price conditions:
Cheap as possible. Must be all in working order (i.e. not from a blown motor or sick motor)
Item:
RB20 Engine Mounts ( **the mount that bolts to the block** )
Extra Info:
needed for my rb25 conversion into my 180sx
Contact Details:
0413348171 or [email protected]
Needed ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by Twisted_SIL80
looking for some stockies to fit my r34, not worried about the condition of them, i just them for when i go on the track so i dont bang up my current rims!
dont want to pay to much, so i really dont care if they are all gutter rashed and stuff, as long as they arent buckled etc, i need to be able to drive on them!
cheers
just send me a pm!
cara
Items:
Drivers side seat rail to suit r32 bride brix 1.5
Extra Info:
must be in good condition
Contact Details:
just pm me or call me on 0401 38 77 26
must be in good condition and let me know how much you want for it
Items:
r33 gtst adjustable coilovers
Extra Info:
any brand must be in working order with no leaks
Contact Details:
just pm me or call me on 0411 758 793
cheap dont wanna pay stupid prices. of course according to condition
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
