sorry guys my inbox was full, now cleaned
im wrecking a complete silver S2 R33gts-t northern suburbs
EVERYTHING FOR SALE need it all gone to fund the track car
also s1 rb25 package engine (minus turbo)/loom/ecu/near new Hd clutch and box
http://www.skylinesaustralia.com/forums/topic/394254-wrecking-1996-series-2-r33-gts-t-sa/
Looking for a stockish GTR32. Have $13k, and looking for something with a strong healthy engine, can have cosmetic blemishes here and there (to be expected for this price.)
Have cash pretty much straight away, if you or any of your friends are looking to sell, PM me or text me and see what we can do.
0432809975
Cheers Josh
0432809975
Cheers Josh
0432809975
Cheers Josh
funny you mentioned that was just having a look in ICI and found this
img_0832.jpg<<<Click
