Hi guys I'm after a R34 gtt nistune ecu..went to go get one tuned to only find out it was a random jap spec dud! :/ car is at tuners still and I need one urgently. If anyone has one or knows someone that's looking to sell, let me know ASAP 0432145854 cheers
Wanted. Earthing/Grounding kit, Prefer GTR but any Skyline model will do
cheers Mike
I might have a set in the shed or I could make a set then they are the right length
Wanted
R32 skyline (coupe) Rear bar – Silver
R32 skyline (coupe) rear bar support
R32 skyline tail-light surrounds (silver)
These bits will allow me to make it out for SAU nationals, after overcooking it at Legend of the Lakes finals on Sunday :(
he guys im after a r32 drivers side exterior window channel that the seal sits in and runs up the a pillar and across the roof ( picture below to help) must be in good condition with no dents etc
let me know if you have one spare
cheers will
You'll be hard pressed to find that bit in decent condition on any car in aus. That rubber strip decays superfast in our climate and they cost around $650 new from Nissan (If anyone can source them cheap, please do let me know)
I want to replace mine too, but they're super expensive and I've been looking for 2 years and found squat.
-D
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
