As the topic states, I got a question about when the car is launched. At times, I have launched it from about 4k revs - this has given the best grip, and the actual take off is very smooth and controllable. However, I was in a friends r33 today, and the launch was done at 6k. The strange thing is, there was no wheelspin, but the rear of the car did momentarily dip downwards as the car started to move forward.
Is this normal (the dipping of the rear)? I guess those who have taken their car to the drags etc - is this what normally happens or the car is not supposed to dip at all?
https://www.sau.com.au/forums/topic/143809-launching-the-skyline/
yes, all the weight transfers to the rear wheels, and compresses the suspension, and because all the weight is on the rear wheels, you get much better traction. many drag cars run soft suspension in the rear, and very firm in the front to aid this. sounds like your mates car has better tyres than yours also...
Other way round. Making the front take longer to return from full extension in the shock aids weight transfer - ala 90/10's. Stiffer rear suspension in IRS cars like Skylines stops the tyre from toeing in and decreasing the contact patch at launch.
i launch at 5,500 - 6,500 rpm and dont have much of a traction problem but takes a bit to keep straight off the line, slicks will top it off on a good launch :)
on the street a 5,000 rpm launch with soft throttle is pretty good.
Edited by LTHLRB
good suspension? and i dump the clutch.. i ride it out at 6,000rpm still spins a little bit, but does launch well.
And as for traction. a 6,000rpm launch on street tyres got me a 1.9 60 footer. :P
Kinda odd that any of you can launch anywhere near 5000+rpm in a gts-t and not get wheelspin....
My car isn't overly powerful at 205rwkw, and there is no way it could launch at 5000rpm without a shit load of wheelspin on street tyres....
Even when it was stock, 5000rpm, and dumping the clutch, or even letting it out slower, would still spin the wheels with ease.
Maybe in a GTR....but really don't see it happening in a GTS-T
same...
evan with new tyres i get the same thing.
ive tried heaps of diff ways of doing it to, like using the handbrake, riding her etc etc..
I have the whiteline/bilstein suspension kit, its not exactly setup for drag racing, but id imagine it should be better than stock stuff.
wouldnt realy of thought its possible doing it at like 5-6000rpm...
Once I get my turbo back exhaust system in place I want to take my car for a run down at wsid and see what it can do... But I have a question being that it is an auto would it be better to go from 0 or launch at like 2,000rpm... on stock everything apart from the exhaust once it gets done. Oh and yeah its a 4 door R34 GT-T if that makes any difference.
Maybe someone fryed the clutch?
I think it was a gradual throttle application - I would like to try it myself, but I dont know if my clutch will take it - and as it is, i think the clutch might be on its way out.......
i dont have much experience with this, but even 4k sounds a bit high to me.
if i go at 3k, hold the clutch just at the sweet spot (on the verge of engagement), for only a couple of secs (it starts to smell of burning), i still get some wheel spin.
but my suspension is too hard, and so every bump causes my tyres to lose contact with the road.
but 5k? sounds like a burnout to me. lol
Edited by Munkyb0y
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
