  • Replies 126
OK so this thread highlights
1. dezz is still an annnoying tool that loves posting shit nealry as much as GTTr34 lieks posing on ns.com
2. Drift is kool like all motorsports some people have bad attitudes.
3. some drifters are infact EMO
4. r31's slide ok until they hit walls
that is all
I like you Roy.. you make great posts >_<. Ima come and cheer your drifting attempts on :D.
Like me ,how? Like i make you laugh? So you think im some sort of a joke? Why i ought to.... :(
Dont cheer me on, trust me the safe bet is to sit with everyone else and laugh and hurl abuse at me when i tank slap into the wall :D Oh i should have been so ashamed but fark it, in this world you got to be able to laugh at yourself :D
that is all
5. go to bed to you can go run that "sighting event" for me tomorrow >_<
Whilst this thread (and the other) has been mildly amusing, it is fast loosing its amusement for a multitude of reasons.
People on both sides of the fence need to pull thier heads in and just relax.
Its the festive season. Grab a slab and enjoy a couple of beers with your mates.
If you drink and drift, your a bloody id|ot
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
