  • Replies 62
hehe yep, pretty much...
Does anyone know someone who would insure an R33 gtst third party fire and theft for its value (about 15k-20k) and the rough prices? I have tried just cars and although fairly cheap, it only covers $4000 of theft (the main thing I am worried about).
you have to hope that the person at vicroads is not a tightarse and just agrees with whatever you said. I think all the weighing gets done at compliance so you probably need to get your importer to "modify" the weight before they register it initially.
Not worth the hassle seriously...either take the risk or get an r32 turbo which is legal.
chill dudes
i had a long hard think about the power to weight laws
but when i saw soo many gtsts with P plates
i decided fook it, jus get it.
so far no problems at all in my car. haven't even been pulled over by cops yet so far. lets hope it stays that way. hehe
jon771-
Vic power to weight ratio explained:
no more than 125kw's per tonne... example: Nissan Skyline R33 GTS-T:
Weight: 1370kg (give or take) = 1.37 tonnes.
Power: 187kw (give or take)
187/1.37 = 136.5kw's per tonne. Illegal
"quoted from SS8_Gohan"
this has also been quoted about 1000 times before! :)
remember the cops apparently read these forums..um yes its legal eh?? :P
correct.
* learners = 1 year, can't drive by yourself, 90km/hr limit
* red Ps = 1 year, lower speed limits, 100km/hr limit
* green Ps = 2 years, 100km/hr limit
i am not 100% sure about the speed limits, but it's something like that. i am on my green Ps still, get my full licence in oct
yeah, i reckon you should drive your mum or dad's car for a while which is probably less powerful.
but no matter what... when you get a fast car you are going to drive around a little faster and do things you wouldn't normally do. the magnitude in which this occurs is just amplified if you are young and dumb
Yeah thats what i did - learnt to drive in it - VT Holden Clubby - real less powerful hahaha
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
