ok I got my notice and got tested:
Hi-Flow Cat, mid muffler + hot dog + HKS Super Dragger = 94dB
Reverted to a stock system (cat back) 87dB.. was quiet as...
So...it appears you would be close to the 90dB limit with a stock zorst + cannon...I assume most people have hi-flo cats etc
To assist others, what results has every1 else got on the test?
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/
I also recieved an epa notice the other week for my exhaust. I was told by a tuner that if you buy about 10 metres of steel wool and jam down the exhaust, u'd surely pass. Then after that, just fang it on boost and inevitably, the steel wool should shoot out the back. I'd have to do this for the fact that i have an ECV welded where the diff sits, thus not being able to change exhaust systems easily. Has anyone tried this trick?
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2711096
From my run in with Office Steve Austin and his bionic hearing...
Fujitsubo Super TI cat back - and when I say 'cat', I mean a pipe shaped like a cat, and when I say shaped like, I mean it looked like a pipe. Standard front/dump.
99dB - wooh!
Put a GTSt stock system and cat on, was a delightful 88dB
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2711104
3"cat ,1 foot resinator :w00t: ....mid muffler :wave: and hot dog :) 95dba.
Had to get a new muffler and swapped it for the hot dog then it was 90dba at 5300RPM(RB26).
The test is flawed because the Muffler joint that tested it with the new Muffler,(which dropped the size to 1.5 inch.)told me at 3800 RPM he had me at 97dba ;) .So much for the EPA really not knowing shit about imports.
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2711728
haha a few classics...
yeah so it seems my theory about stock zorst + cannon will probably be over..
which means...basically the whole world of import drivers are over - man I was looking at my stock on the car...looked so sad...was was quite overcome..
just wait for the new twin cannon system I just designed...should be on by the end of the week.
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2711741
Just wondering, are you testing it at ~4000rpm?
well i doubt it, thats not where they are to be measured.
It all changed about... umm... 18 months or so ago :laugh:
RB20 is 4200 or 4300
RB25 is testing @ 4600 or 4800
RB26 is 5200
The RB26 figure is right, i've checked it. But the others im not sure about as i cant remember.
Been just over 12 months since i've been to the EPA, soon to go back though
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2712063
mate of mine got done is his VP SS and racked up 129db , since then the car has been sold.
but the test must be done in an open area, the testing peice must be on a 45degree angle , 1metre away from the exhuast.
another close mate got done in his integra with a stock exhaust, all he had was a tip and they shoved the thing right infront of his exhaustand he went over the limit
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2712783
The calculation is worked out on the RPM using the following method.
Power of car x(by) 3/4 =RPM of test.
I think by memory also.....no turbo rotary(RX) can pass the test because RPM of there test is like at 7000 :ninja:
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2713066
come on guys it's so not hard to find the LEGISLATION on the internet.
speculation is hopeless.
http://epanote2.epa.vic.gov.au/EPA/Publica...;FILE/317.1.pdf
edit: nissan engines Page 63
My computer nearly crashed....please....don't open it :D .
If it is that long....it has no worth to me.... :D
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2713893
its 4800rpm for the RB25...you could have just asked...I got it tested 2 times this week...
twin system in the mix...I'm getting my V2.0 system tested by my mate just to see what it does with silencers and without..
https://www.sau.com.au/forums/topic/145112-epa-and-zorsts/#findComment-2715315
    • Had a chat to Tony Mamo - he advised that looking at the graph's shape (regardless of number translation) it shouldn't be levelling off like that up top. He said it looks like the car is running a restrictor plate or something of that nature. Luckily the last dyno pull on E85 was saved to the PC - So I did a quick trace of Barometric KPA vs Intake manifold pressure, and lo and behold I see a copy of the 'waves' I was seeing on the dyno: I'm not entirely sure how to go about addressing this. It may be worth sacrificing IAT to run a more direct intake for the motor. Though packaging this could be flat out impossible given the constraints of the car. I should have removed the intake pipe to see if this made a difference but looking at this graph I now have something to potentially test in the future and think about.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
