  • 1 month later...
  • 4 weeks later...
  • 1 month later...
They are in the members section but a bit late putting these up in here, but finally some pics with a proper camera just after it was detailed. Was off road for the best part of a year getting rebuilt so needed some love
  • 3 weeks later...
Some experimenting with light painting last night in Freo - a little dark but turned out alright I think.
And one with 3 x speedlites (so hard to get rid of specular highlights....)
Edited by 32godzilla
you should do some photos of your stagea aswell.
Cheers mate - the Stag's really hard to photograph well due to being black - to do some at night I'd need around 10 speedlites I reckon!
Here's one I took last year, bit too much angle on the photo but the paint looks good.
WTF shane, you can take a better picture of the rig than that!
Yeah probably, but I would have to wash it, maybe even polish it, find a spot and use something other than my phone........
And then I would see all the blemishes etc, like seeing a stripper in coles...
I'm a lazy opportunnistic photographer, walked back from Little Creatures on Friday and seemd like a good idea.
Also this is not a comment..... :)
  • 4 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
