just downloaded it (i luv cable). Been hanging to watch it since jack told me he recorded it. I watched a little but the visual part kept freezing while the audio keeps going, prob just my comp :D
Hey Andrew, did you edit it??
I'm assuming you edited it, coz I didn't get on the track until 7 minutes into the video.... no use in me downloading it....
I have just uploaded it as it was.
I think I have figured out how to stream it so it will be easier to watch.
I have put a much smaller version up in the original link. Was 297mb now is 170mb after some editing.
Regards
Andrew
Edited by BBGTR
Upload it to google video, they will let you upload that much..... just need to use thier software to upload it...
Thanks Ferni,
I'm uploading it now and will replace my original d/l link when it's finished.
Cheers
Andrew
Regards
Andrew
That's much better....
Thanks Andrew..
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
