  • Replies 58
In respect to my power run above,
can anyone shed some light
on what power and torque figures
are expected with the pfc?
Also, should i run an adjustable fuel regulator,
just to be sure it does not lean out in top-end?
Perhaps, a nismo f.p.r.
PS - no money for injectors atm. :P
Anyone?
you are better off saving $$$ for injectors and do the fuel system right the first time.
fpr's are just a cheap excuse for inadequate fuel system.
if this is on the RB25 look into a couple of sets of S15 injectors (440cc/min side feed), you can pick them up for $200-300 a set
Ill try hunting a set down today.
Judhement Day Today... :(
I put her on the dyno for a tune with the PFC
She made 238.2RWKW on 13 psi with some slight detonation up top
Knocked back some timing and ran her again safely on 13psi to make 237RWKW
with approx 590N.M torque in third gear close to redline
This was at 100% injector duty cycle and to add my little apex fmic
heated up really badly, inlet temperatures were quite hot.
So next modes coming are probably a garrett fmic/hybrid and 444cc S15 injectors
Will post AFR, PSI and Flyhwheel torque graphs tommorrow, all sheets
have stock and new turbo side by side for comparison.
So all mods are as follows:
HKS dragger + 3" frontpipe
Apex FMIC (300 by 150 by 40)
Im guessing I have a bigger fuel pump :D
Apexi Power FC
Garrett GT3071R (Integrally Gated)
Stock: injectors, fpr & dump-pipe
Previously:
I was running an SAF-C SII and stock turbo
and made 211RWKW on 14psi
PS - She F*&%$KKKKKIN' PULLS IN THIRD :sorcerer:
Its Calder parks final drag racing meet for the year this Friday the 15th
If you compete in it, as a Christmas gift you get to enter again in January
next year for FREE.
So ill be there...trying my best with my worn tyres :P
But in January ill be back with M/T semi slicks ;)
Will post up time slips when I get a chance.
Edited by Nabil
Its tomorrow... Wheres the dyno sheet. :O
What Ign timing are you running up top where you were experiencing det?
Drop the afr's a touch 11.5:1, push more boost in and start pulling that timing back until she begins to make less power. :sweat:
No, not a typo.
I guess ill have to wait and see.
Created Motorsports white drift R33 had this set-up
but with a t25/28 flange and 0.82 ex a/r
and he made 269rwkw with a significantly linear power curve.
I was under the impression that it was hi-flowed to around 82, reason being the rear housing is being changed to a new garret style internally gated 35R something like a 3582 (or thereabouts, new from garrett aparently), car has been running dramas suspect actuator and its rear housing was too inefficient for its application.
Having said that it was a verry respoisive turbo.
You should have fun with your setup, but i think it could be a little too restrictive if your chasing over 280 at the wheels easily with a standard engine.....It seems more suited to a RB20 the more i look at it, although the response would be a pig.
my 2cents
-Jez
Edited by Wheezy
PSI Graph
Starts boosting at approx. 3100rpm and reaches
full boost at say 3950rpm
Stock turbo starts boosting
at 2850rpm at reaches full boost by 3000rpm
Edited by Nabil
Tractive Torgue Graph in 4th Gear
Peak torque transferred to the rear wheels
in 4th gear is approx. 460N.m at 127kph
Has heaps more mid range and pulls hard to redline.
(Damn should of asked for Torque vs. RPM) :dry:
Edited by Nabil
Its tomorrow... Wheres the dyno sheet. :dry:
Drop the afr's a touch 11.5:1, push more boost in and start pulling that timing back until she begins to make less power. :P
Not sure when it occured but
its possibly somewhere beyond 5500rpm.
It needs more boost to pump up that mid range some more. :)
None the less a nice power increase considering boost is essentially the same.
Thanks Cubes, shes got more in her...ill
have to wait and see with bigger injectors
and a cooler. :)
Cheers,
Bill
  • 11 months later...
  • 1 year later...
Thread revival FTW :)
Have you developed this thing any further Bill?
I haven't I'm afraid and it brings a tear to my eye.
I sold the turbo kit to another dude on this forum.
I hope to find out one day how he went with this set-up.
I'll be back on this forum soon when I get back in my
garage and stir some horsepower up! lol :D
Sorry for the long awaited reply! :D
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
