  • Replies 58
In respect to my power run above,
can anyone shed some light
on what power and torque figures
are expected with the pfc?
Also, should i run an adjustable fuel regulator,
just to be sure it does not lean out in top-end?
Perhaps, a nismo f.p.r.
PS - no money for injectors atm. :P
Anyone?
you are better off saving $$$ for injectors and do the fuel system right the first time.
fpr's are just a cheap excuse for inadequate fuel system.
if this is on the RB25 look into a couple of sets of S15 injectors (440cc/min side feed), you can pick them up for $200-300 a set
Ill try hunting a set down today.
Judhement Day Today... :(
I put her on the dyno for a tune with the PFC
She made 238.2RWKW on 13 psi with some slight detonation up top
Knocked back some timing and ran her again safely on 13psi to make 237RWKW
with approx 590N.M torque in third gear close to redline
This was at 100% injector duty cycle and to add my little apex fmic
heated up really badly, inlet temperatures were quite hot.
So next modes coming are probably a garrett fmic/hybrid and 444cc S15 injectors
Will post AFR, PSI and Flyhwheel torque graphs tommorrow, all sheets
have stock and new turbo side by side for comparison.
So all mods are as follows:
HKS dragger + 3" frontpipe
Apex FMIC (300 by 150 by 40)
Im guessing I have a bigger fuel pump :D
Apexi Power FC
Garrett GT3071R (Integrally Gated)
Stock: injectors, fpr & dump-pipe
Previously:
I was running an SAF-C SII and stock turbo
and made 211RWKW on 14psi
PS - She F*&%$KKKKKIN' PULLS IN THIRD :sorcerer:
Its Calder parks final drag racing meet for the year this Friday the 15th
If you compete in it, as a Christmas gift you get to enter again in January
next year for FREE.
So ill be there...trying my best with my worn tyres :P
But in January ill be back with M/T semi slicks ;)
Will post up time slips when I get a chance.
Edited by Nabil
Its tomorrow... Wheres the dyno sheet. :O
What Ign timing are you running up top where you were experiencing det?
Drop the afr's a touch 11.5:1, push more boost in and start pulling that timing back until she begins to make less power. :sweat:
No, not a typo.
I guess ill have to wait and see.
Created Motorsports white drift R33 had this set-up
but with a t25/28 flange and 0.82 ex a/r
and he made 269rwkw with a significantly linear power curve.
I was under the impression that it was hi-flowed to around 82, reason being the rear housing is being changed to a new garret style internally gated 35R something like a 3582 (or thereabouts, new from garrett aparently), car has been running dramas suspect actuator and its rear housing was too inefficient for its application.
Having said that it was a verry respoisive turbo.
You should have fun with your setup, but i think it could be a little too restrictive if your chasing over 280 at the wheels easily with a standard engine.....It seems more suited to a RB20 the more i look at it, although the response would be a pig.
my 2cents
-Jez
Edited by Wheezy
PSI Graph
Starts boosting at approx. 3100rpm and reaches
full boost at say 3950rpm
Stock turbo starts boosting
at 2850rpm at reaches full boost by 3000rpm
Edited by Nabil
Tractive Torgue Graph in 4th Gear
Peak torque transferred to the rear wheels
in 4th gear is approx. 460N.m at 127kph
Has heaps more mid range and pulls hard to redline.
(Damn should of asked for Torque vs. RPM) :dry:
Edited by Nabil
Its tomorrow... Wheres the dyno sheet. :dry:
Drop the afr's a touch 11.5:1, push more boost in and start pulling that timing back until she begins to make less power. :P
Not sure when it occured but
its possibly somewhere beyond 5500rpm.
It needs more boost to pump up that mid range some more. :)
None the less a nice power increase considering boost is essentially the same.
Thanks Cubes, shes got more in her...ill
have to wait and see with bigger injectors
and a cooler. :)
Cheers,
Bill
  • 11 months later...
  • 1 year later...
Thread revival FTW :)
Have you developed this thing any further Bill?
I haven't I'm afraid and it brings a tear to my eye.
I sold the turbo kit to another dude on this forum.
I hope to find out one day how he went with this set-up.
I'll be back on this forum soon when I get back in my
garage and stir some horsepower up! lol :D
Sorry for the long awaited reply! :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
