As per the title.
The ones that spray in a chinese fan shape/pattern instead of the oem 2 jets. No leds or chrome etc just want the plain black ones.
I had a set in the 32 ( sold car with em :D ) Need a set for the 34 now. The last set I got in Japan but that's a bit far to go to get another set.
Check Post #39 for buyers status.
Check Post # 40 for installation guide.
https://www.sau.com.au/forums/topic/146412-fan-spray-washer-nozzles/
  • Replies 90
Scott you should be able to get them from Nissan, or if you wanted a different style maybe get the autojoy ones (or whatever theyre called) and paint them?
Shouldnt be too expensive
Arent these all common fitment though? So HEAPS of brands will also fit?
  • 3 weeks later...
They are factory on most new Toyotas.
the previous shape camry's have them.
if u ring toyota, give them a model code of ACV36 or MCV36 and give them a month and year production of 8/04 onwards.
hope that helps.
Cheers :huh: I'll give it a go and report back.
I called Australian Auto Accessories in VIC and they don't stock them any more. Only have the LED ones. :)
^^^ How much are they worth? I just want sprayers, dont care if theres LEDs on em, I'll tape over em :mad:
Didn't ask since they didn't have what I wanted but feel free to call em on (03) 9845-0800
I know for a fact that Autobarn Bankstown stock fan spray ones with LED's and some silver/bronze coloured ones without LED's if that's any good to you. ;)
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
