Ben,
I have the same LM GT4 (19/10.5 +15).
How did you manage to get your rear wheels to sit so far in/under the guard. My rear rims stick out a lot more than yours.
And I think you mentioned your tyres are 285 wide. What brand are they?
Thanks
MIchael
Hey Mic, now you've got me stumped, as they just bolt on mine! Tyres are Nankangs. Pics of yours mate? I'm interested to work this out.
I need to meet someone with a decent camera! lol Here's mine, snapped with a 2 meg Nokia :laugh:
Nice C-West body kit!
Nismo LMGT4's looks GREAT!
You need a better offset in the rear tho.
More of a Negative offset to fill out your rear guards.
IMO :D
Here's the pic Benny
I'll snap a pic of mine on flat ground in the garage this afternoon. I'll also grab a straight edge try and gauge some measurements re gaurd clearence with that.
It's also worth noting I run close to 3 degrees of neg in the rear.
Edited by Marlin
IMO :D
Thanks mate :laugh: These genuine kits are so nicely made! I was astounded to see the quality compared to our home grown copy stuff.
Without much camber in the rear, the wheel is actually nearly level with the gaurd, but as I've now got about 3 degrees on it, it moves the upper wheel in a little. I small spacer would be sufficient if it bothered me, as I'm not going to order new wheels, they're kind of expensive. I'm led to believe these are also the only offset that Rays make them in 19x10.5. :D
Thanks mate :P These genuine kits are so nicely made! I was astounded to see the quality compared to our home grown copy stuff.
Without much camber in the rear, the wheel is actually nearly level with the gaurd, but as I've now got about 3 degrees on it, it moves the upper wheel in a little. I small spacer would be sufficient if it bothered me, as I'm not going to order new wheels, they're kind of expensive. I'm led to believe these are also the only offset that Rays make them in 19x10.5. :(
If I were to go a full body kit on a R34 GTR, C-West would be the one, with the Version 3 Front Bar. which I think it what you got.
Can't say I am a fan of the silver mesh though...
Or Nismo Z-Tune Front guards and Nismo Body kit is another I would go for.
Ah yes, spacers will help! +1 for that.
I too have a (from memory) 5mm spacer in my rears, just give it that extra fill out.
What offset is your wheels?
Is that the Yokohama ADVAN R34 GTR in the last pic?
As in the Hi Octane Racing one?
That car is Friggin awesome!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
