uk front bar???
if your talking about the r33 then its just the vents that come with the nismo oil cooler
You get those "add on's" with the cooler kit? Its $2000. Bit steep for a cooler and a few bits of plastic. :(
i think he means coz it was standard on the uk delivered cars no?
Exactly.
Perfect fucntion yet looking standard. Uhuh!
yep, u need sum way of getting enough air to the oil cooler when its put behind the front bar.
You should know that when ever the word nismo is mentioned in the product that its not going to be cheap.
Im actually supprised that no one has made a replica copy of them as im sure there would be a market for them
I put my oil cooler on the drivers side front bar and just used border carbon ducts as they allow enough air with bigger openings.
If they did come standard on uk model cars well then lucky them
Does anyone know the story behind this thing? Is it genuine? Saw it at the Showcased event and it looked pretty damn good as far as I could tell.
The only thing that caught my eye was that it seemed to have a series 1 rear Nissan badge (old Nissan logo) but had a V.spec II badge which AFAIK = series II. Plus it has a V.spec II bonnet.
http://www.the-lowdown.com/s-tune-gtr/
not sure whether its a v-sepc or not.
it came up in conversation here with Kristian (Iron Chef) when discussing S-tunes and R-tunes
http://www.skylinesaustralia.com/forums/topic/393240-swap-n1-r34-gtr-for-r35/page__st__40
maybe it was built to V-spec spec when it went to Omori.
After seeing the car in person and speaking with the owner. We both take our cars to chasers. Yes it is real!
Yep, it's a real Nismo S-Tune.
I'm actually not sure if that is a real S-tune. I know it has the S-tune engine (I think) but I took a photo of this car back when it first arrived. as white lmgt4's, and no sticers on it :S
And yes, it was claimed to be the S-tune.
I will check my pics again, but I remember a Nismo Build Plate in the engine bay.
just came across this s-tune by total coincidence!
http://www.nagtroc.org/forums/index.php?/topic/33415-nismo-s-tune-r34-nissan-skyline-gt-r/
^^ Great R34 GTR but would prefer other type of wheels.
More pics of this car earlier this year:
Not too sure why it has a "fukuoka Factory" sticker on the air intake when clearly the engine build plate says Omori Factory.
And looks to be the car now has a Nismo Intercooler and Black LMGT4's.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
