I'm sure it will mate! Your 34R is the best I've seen in yellow. I got one set of stickers previous to those but I didn't like the outline, so found the red set which were perfect
Cheers mate. Yea ny wheels are te37sl but I didn't like the red with the yellow, so will see how they work out. Will post pics once there on.
Dang son, very well done. What are the specs on your wheel fitment?
Also, how did you tint the reverse lights?? DIY?
Cheers Tom,
19x9.5 +12 all around, front and rear guards are both rolled to flatten the lip and pulled out a few mm.
Reverse lights are tinted using a gloss black tint film (not like window tint) i stock, as were the rear indicators which i now have precut pieces to suit 34 tail light indicators. The beauty of it is when you throw it in reverse or put on your indicators they are still clear as day, almost no reduction in brightness with the tint film on.
Cheers Tom,
Sounds the goods Stephen, I just bought some cst zero-1 hyper in 18x9.5 + 15 all around, so the fitment should be very similar to yours :yes: . What tyre sizes are you running, and do you get any scrubbing on full lock?
Considering you run a graphic business, I'm guessing you can supply the tint film?
PM me details if this is the case :thanks:
Ah very nice,
Tyres are 235/35/19 up front and 265/30/19 rear.
With the front plastic guard liners removed there is almost no scrubbing on full lock.
I'm thinking of adding camber arms to give it just a little neg camber and also hopefully help it tuck more when leaning into a corner/going down a large dip, as if i corner too hard it will scrub a little on i believe the guard. Also going down a dip really fast which naturally compresses the coilovers tends to cause a little scrape.
Will send you a PM regarding the tint film.
Some pics I dug up off my hard drives.
Love em!!
Hey thats my car :) , geez long time since that photo taken some changes since then. ( wheels, bonnet :) , some slight damage to lower lip :( )
Glad it made it onto the must keep photos lol
Its actually a Fluro Orange, (Which you prob still might not like lol) the shitty iPhone Camera does not even show you how bright these are, thought they would be something a bit different for summer.
They were originally a white rim and I Plastic Dipped them.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
