Because POV spec lol
Currently making the front diffuser, should be on in the coming weeks.
Mad picture.
Oh ok just saw nismo side skirts.
A mate has a MNP III and got his skirts pods and spoiler colour coded, did an excellent job on the match for the flip paint; might be able to put owner in touch with spray painter if interested.
Cheers Matt,
If I ever need MPIII paint I'm all good, I have a local supplier for this. Can mix this perfect.
As Simon said the added parts I made are carbon so if I ever paint them it will just be a protective clear coat.
I'm happy the car is coming along slowly, Diffusers and Nismo front vents will be fitted in the coming weeks.
I may order a new lip from Nissan and get it colour coded when fitting the front Diffuser.
Noy
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
