Perfect choice of rims 34GTV, car is looking fantastic as always.
I'm also a huge TE37SL fan.
Nice Chris; I think you're gradually turning you car into my car's twin. Been pricing Nismo S-tune front bars by any chance? :P
That looks awesome chris massive difference.
All the cars on here look great.
We are going to try this sort of shot with my car, mine isnt pretty but would be good to see the engine bay as that is where the money is haha
Any tricks to getting this right? Or just a decent tripod setup? Was the bonnet up or off for the engine bay shot?
Yes, mean look!
Be careful about the angophera (red gum) across the road. They can come down easily in high wind.
And it looks as if it already has bores in it - but hey, most of them do.
You are a wealth of knowledge Terry :D
Yeah looks pretty tough man!
Dam that looks mean! Great shot mate!
Cheers fellas :)
Yes, mean look!
Funny you say that as a rather large branch fell a couple of weeks ago! And ofcourse due to silly council rules/regulations I cant remove the tree so I guess shes there to stay.. Thankfully the front yard can fit up to 5 cars easily and that spot near the tree is always vacant.
Plus the GTR spends her time sleeping in the garage and comes out once in a blue moon so apart from damaging my concrete there isnt much that trees falling branches can take out.. unless the whole bloody tree topples then im well and truelly stuffed! :ph34r:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
