Damm... thats gonna be some wide rubber on that.
Reminds me of my mate who bought my GTR offset old XD9's and put them on his R32 GTST... Looked phat but guards had to be really really rolled lol
Yeah just rota's but I really like to look of them and to me thats all that really matters...enough for me to swap my SSR's for them in fact
Ganna go for a big stretch, camber and some guard work to get it sitting perfect because I dont think Ive seen many stanced 34's
then the wheels will be painted
