Many many thanks Craig.
I'm a lucky man!
He's a lucky lucky man. :)
Many beauties there are indeed!
When we organised the R34 GTR 10th Anniversary 5 years ago I was absolutely gobsmacked when one tallied up millions of dollars of machinery present on the day!
And yet we have bang for your buck type cars...
Absolutely amazing!!!
Cheers guys - appreciate the kind words. Terry, it's hard to find good royalty free music that's reasonably priced to put on youtube, I think this one worked well. Not exactly sure who it is though! :P
http://audiojungle.net/user/MusicPremium/portfolio
Great music selection all the same Craig!
A very regretful post to make but I've run into a bit of trouble :closedeyes:
Pics of before and after
Ganna be some work to get the poor thing on the road again :(
Fucckk man! what happened?
This was honestly my favorite 34 as well :(
Hopefully she is back on the road soon mate.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
