Alright boys and girls. Here is a offer you can't refuse. I have 13 spots to fill for a paintballing spree all it will cost you is for your balls as i have 2 VIP passes and i thought of all you guys first.
Prices for your first 100 balls is $25 and $22 for each additional 100 balls.
If you are interested plaese post up your name and once we have enough people keen enough to go we will organise the day pretty much going to be a saturday (need to recover) and sometime after the new year.
Once the date is sorted and everyone agrees all we will need is your first 100 balls paid for in advance.
The day includes all your equipment (helmet, clothes, Chest/breast plate and your rifle) also included is lunch. So come on everybody and lets have some fun. :laugh::miner:
EVERYONE HAS TO BE OVER 18 YEARS OF AGE
If there are any questions please contact Daniel and Emily on 0400694881 after 6pm on weekdays and anytime over the weekend.
https://www.sau.com.au/forums/topic/146689-paintball/
  • Replies 200
went a week ago for the first time, went to farbairn it was awesome possibly be up for this depending on date and cash situation
and beau i still have a mad bruise on my arm from one that didn't break :(
https://www.sau.com.au/forums/topic/146689-paintball/#findComment-2739683
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
