Hi guys,
So it seems we're down 3 spots now... If anyone wants to bring a friend you're more than welcome. Daniel and I are bringing one friend so there's 2 spots. Just make sure their deposits are in by Friday. If all deposits are not received by then, the date will have to be postponed. So come on guys let's do this! :cool:
  • Replies 200
Hey guys!
Finally have the good old internet up and running! :laugh:
So, seems like most people are good to go on the 27th so THAT'S THE DATE. If you can bring along friends to make up the numbers please just let me know by THIS FRIDAY and have deposits this friday, saturday night at the latest (be at the museum both nights).
Bank details are as follows to speed this up and not PM each person:
BSB: 062593
Number: 10294940
Branch: Commonwealth
Thanks for your patience to those who have placed deposits, this is my final offer for the 27th. If not, it will be put off for 1-2 months depending on how long it will take to arrange ANOTHER day with those who have already paid their deposits. So come on guys, you have another 4 days let's just make up the numbers I don't mind who'se coming. :D
As for Contempt, it's $25 for deposit (your first 100 balls) and $22 per 100 after that on the day lunch and everything else is included.
List:
SL33KY (Emily & Daniel + 1) Deposits taken
Bluprint
Sinista32
CeJay
Cef11e
LTSJayce Deposit taken
Contempt (plus how ever many)
supadan
Jai Jai (possibily)
Veilside R33 Deposit taken
Skylvia
a20089
2 MORE SPACES LEFT OPEN, I DON'T MIND WHO FILLS THEM, JUST FILL EM AND GET THE DEPOSITS BY FRIDAY/SATURDAY FIRST IN BEST DRESSED.
27TH JANUARY IS THE DATE
5 Deposits all up taken only need 11 more saturday night is the last chance for the 27th
Edited by SL33KY
Hey guys!
Finally have the good old internet up and running! :)
BSB: 062593
Number: 10294940
Thanks for your patience to those who have placed deposits, this is my final offer for the 27th. If not, it will be put off for 1-2 months depending on how long it will take to arrange ANOTHER day with those who have already paid their deposits. So come on guys, you have another 4 days let's just make up the numbers I don't mind who'se coming. :ninja:
List:
Bluprint
Sinista32
CeJay
Cef11e
supadan
Jai Jai (possibily)
Skylvia
a20089
I'll drop over to the museum on Friday night. What time do you guys usually meet there these days?
cya
cya
We are usually there from 9.30 pm and there till bout 11 or later depends on the weather.
So come along and meet your team mates/rivals.
see you then
Thanks heaps! Come on guys, keep up the good work! :) SLOOOOOOOOOOOOOOOOWLY getting there.
List:
Bluprint (should be taking tomorrow)
Sinista32 (should be taking tomorrow)
CeJay
Cef11e
Contempt (plus how ever many) (deposit taken)
supadan
Jai Jai (possibily)
Skylvia
a20089 Deposit taken
Daniel and I will be out there (museum) tomorrow around 9.30, see you then.
Edited by SL33KY
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
