  • Replies 200
I did have an idea about hiring a mini bus but noone has said anything so unless everyone puts in for one it is make your own way. we are taking a barina out there big loss of power :)
I'd happily chuck in for a minibus. I have this strange aversion to leaving my Z anywhere it is likely to get trashed or broken in to... don't know why :)
Hey guys well the price of a 12 seater minibus will be $150.53 for the day plus fuel (probably) it is a turbo deisel so at least we won't lose our turbo ;) the price for each person will be about $12-$13 plus fuel if need be but fuel would only be another dollar or 2 each. So he who wants minibus say I! :sleep: So 3 or 4 people need to arrange their own way sorry. So yet again first in best dressed.
We are going up there today to check it out anyways! :wave:
Edited by SL33KY
I'll be driving out too; room for a South-sider if they're quick to PM me... However,will be needing to leave or hang around afterwards at my own discretion,so....s'up to you,tag-along!
P.S. Can we get the list of paid up entrants again? My mate who wanted in isn't sure if he's actually "in" or not...and I'm not positive he is,either.
Hey guys this is the list, we have been told now they double booked and we have been moved back to Sunday 4th March :kiss:
List:
SL33KY (Emily & Daniel + 2) Deposits taken
Bluprint Deposits taken
Sinista32 Deposits taken
CeJay Deposits taken
Cef11e Deposits taken
LTSJayce Deposits taken +1 need deposit (this is the last person we need)
Contempt Deposits taken
Veilside R33 Deposits taken
a20089 Deposits taken
James (sorry don't know your screen name) Deposits taken
SKYLVIA Deposits taken
Baconer Deposits taken Paid up
Sorry for the change or date guys, this was out of our control. The booking has been made so if you cannot make it, please try to find someone to take your spot as it has all been paid for.
Yes we will, the booking has already been made for the 4th and are non refundable as we have already paid. If those who cannot come can find someone else to fill their positions or we find someone to fill your spot we will refund your $25 (this will be a last resort). So come on guys let's make this work, I know it has been hard with the date changing but we had no choice. :):P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
