yeh i removed mine 12months ago and have not had a problem,but that dont mean shit,just leave it in and wait till ya get cash for new turbos,or risk blowing them or ya motor or both in a worst case senario....
my2c
my2c
do r34 GTRs have decent turbo;s meaning should be ok for him to run about 13 psi?
This thread is pointless. R34's do not have a boost restrictor. They have a marking where a restictor would be but they do not have a restrictor like the older GTRs.
As Geoff has already mentioned - R34 turbos are ceramic wheels with ball bearings. Mine was running 1 bar from the factory after I put a cat back + hiflow cat on it. They do this all day long and will go the distance.
If you want to pull a restriction out open up your airbox and check to see if you still have the factory plug in the wheel well intake hole. Pull that plug out and go for a drive. Sounds good :P
What he said is all correct but if a turbo lets go you risk sucking back the dust in the engine just like all other RB26's .
are you sure? I know the gtt has but according to HPI mag,the GTR 34 have steel.
I think they would have been refering to the Nur Edition (VSpec and MSpec), it had the steel wheel turbos (N1 spec), and they were the last of the R34 GTRs that were made. They also got other N1 component to make up the engine.
When I was changing the actuator I had a closer look at the turbos, There are the same as what they had in the picture, 0.53 inlet housing?
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
