  • Replies 392
The following member payment is now confirmed:
Adam (R32-PSH77)
Sorted
Col
last time i ran on the dyno, it pushed out close to 250rwkw, so i think it would be best to strap mine down also
No worries Shane... Can be done... :)
Side Note: Those who have not pmed me or SMR33 with their payment confirmation and have paid and your name is still in yellow can you please sing out. As atm its assumed all those in yellow still are not running and I need to know asap. Thanks
Col, my $$ transferred today - I'll need to have my car strapped down.
No worries, Richard has said he is only gonna strap down cars with 300+rwkw not the original 250rwkw...
So if you have over 300rwkw just place a note on your dyno entry form and mention it to Richard as you hand him your keys to your car...
So ive updated the first post...
I am very interested. Is there any spots left. If so I will pay my dues.
Pm replyed and forwarded to SMR33 :)
Ok Col. My dues are paid. It will be interesting to see what power my car makes. As far as I am aware it is only stock, that is what I was told when I recently purchased it anyways, but it will still be good to know. Looking forward to it.
YEAH!!!!
Me and bunts wanta wind up the boost... :happy:
Just for the dyno of course... :D
well, if that's the case..... i need NOS. I need one of those big ones. Actually, let's make it two. and Harry... i need it by tonight.
Just so there is no confusion, the pdf file for the running sheets has the old address on it. Allstar Tuning is on Delta Street in Geebung now (recent move) - edit: Address has been updated on first post
Can everyone who is running please download and print the running sheet and have it filled out on the day so I can come around and add a number to your windscreen and running sheet. This is to speed up the process and make it easier for Richo to marry up cars with their details so the Dyno readouts can be processed quicker.
Thanks.
I'll be in for this one. Just did funds transfer. Got on a dyno the other day that I dont think was reading right. My mate only made 177rwhp, but when it got tuned 2 weeks ago was making 200rwhp with less boost. Also want to see what my flat spot looks like. haha
Edited by Spooner
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
