  • Replies 392
170kW [evil] Muuaaha ha ha ha haaa [/evil]
very pleased with that. stupid speedo is out though :S says 80 when the car is doing 86.
So thanks everyone for an awesome day.
My car bombed out because of a fuel problem, could only get 147rwkw before they backed it off coz it was running dangerously lean, so on the way home i ordered myself a walbro fuel pump.
95rwkw >:D
pooooor
but the object was to get a starting figure before i start my mods. Considering this dyno runs low, say what, 105-110?
Brilliant day out, saw some really really mean cars, and some just made my jaw drop in amazement.
Trying hard to bite my tongue here. All I will say is, how can you have a level playing field and get accurate figures when they were fiddling with ramp rates etc on almost every run for at least the first 12 cars, trying to get it right.....
At the end of the day not too bad at all glad to see Col take out the over 300rwkw challenge even with wheelspin still happening, Verry good day and well organised, awaiting results
That should get you by until you can put in a decent pump :D
On a separate not, appeared to well organised...everyone was friendly as usual.
One thing I would like to say, as Lazy has, how can the runs be accurate when the ramp speeds are constantly changed. I also noticed around 6 cars that wheel spinned on the rollers and 5 of them I know should be making more power than the result. Chris (Pear) made 156rwkw and had wheel spin. I mean, I know they could hear it...so why didn't they do something about it. Col made 280rwkw with wheelspin, Adam made 220rwkw with wheelspin but they only gave him the 210rwkw printout, Chris had wheelspin, Andy had wheelspin...
I've been around dynos for a number of years and the only car I have seen with wheelspin was a 600rwkw GTR in RWD mode.
Not saying dodgy, just saying they should have done a little more to make it better.
first up... nice job to the execs for pulling it off. they were organized and had most of the stuff down pat. dave was on the ball with who was running next and who needed to be ready.
secondly, all star tuning - what a joke.
they are the most unorganized workshop i've come across. the dyno should have been ready to roll and calibrated with the CORRECT settings well before we had the first car on. it is understandable that all dynos read differently - some high, some low. but consistency is the key, my figures were all over the shop some varying by up to +/- 20kw.
the staff are NOT helpful and quite vague in answering questions and most importantly were far from enthusiastic.
a good day from SAu, but a thumbs down for all star. i have felt that my time and money were wasted by an unprofessional workshop.
i certainly hope we can include a well reputable 4wd dyno in future to accomodate the 33 and 34 gtr drivers without dropping the front shafts, and not favor a workshop whom some of us have had work done at.
congratulations to the others. it was good to catch up with a few old faces and a few new ones too!
All results and pictures and video is being worked on atm...
In the mean time ill move these posts to the new dyno day discussion thread in the general qld section...
But before closing this thread, a big thanks to everyone for coming along.
Huge thanks to the sau exec crew for the bbq and handling all the payments and the like.
Huge thanks to Richard and the Allstar crew for hosting an awsome day.
Thank you all.
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
