Rb20det Coolant Type
i have just used any old antifreeze/antiboil from supercheap for the last 4 years without 1 water leak
in my opinion, as long as you get something that's got corrosion protection, antifreeze/boil, and meets australian standards then you're laughing..
also add half a bottle of the royle purple stuff for ur raidator mix it in with ur coolent, this stuff is amasing, i have an after market temp gauge an b4 i put the royal purple stuff in was siting at 100 degrees an after it was 85 degrees. makes a big difference.
I don't see how an additive can make such a dramatic decrease in coolant temperature. Do not use the red coolant because green coolant was originally used from factory. Use nissan coolant and you can't go wrong. Also make sure you flush your coolant out properly and not just by dumping all the coolant out through the bottom of the radiator. Take off one of your heater hoses near the top of the firewall and stick a hose down it until fresh water starts coming out, then fill it up with coolant through the heater hose again. Then bleed it properly with the heater turned on, and bleed bolt off to get rid of any air in the system.
Don't use "red" OAT type coolants in an older car which never came with it factory fill in the first place.
Green coolants that would work well are the Nissan OEM, Nulon Long Life, Castrol Radicool or Tectaloy 90 Plus and you cant go wrong.
Btw that Purple Ice/Water Wetter stuff works optimally with straight water and its effects are very much diminished when mixed with glycol coolants.
Up until recently I thought the special-ness of the Nissan coolant came from the 10mg/kg dentatonium benzoate, like Castrol. Until I found this is only a bittering agent used to prevent people ingesting antifreeze. By law this chemical has to be present in certain countries in any anti freeze sold, though not in Australia.
You need to achieve the Nissan Glycol levels reccomended at any rate, going el-cheapo can mean issues with concentrations. The glycol levels drop when exposed to sunlight which is why I buy Castrol 350 concentrate, to ensure the levels haven't dropped while sitting around in some freight yard for a week.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
