  • Replies 182
Posted Images
Well Liz has had enough looking and feeling like crap so
here are the last of the pics
got the boot open and well lets just say that she is lucky that she is not hurt the boot is cracked in areas and it is looking like a smiths crinkle cut chip in the boot :(
Lizzy,,,glad your alright girl. I was very worried when I 1st heard.
As fatzman said,,,drag the bits out and start again,,,pity really,,,I liked naths work. What about a Gazelle coupe this time?.
I'm just glad your okay.
Neil
that sucks liz. it's always harsh to get punished for someone elses mistakes. i hope you have comp insurance and if you do, ring them right away. I have been screwed twice in the past when un-inured knobs hit me, and my cars were also un-insured at the time. the first time cost be about a grand and the second time about three and a half :( now i always make sure my cars have full comp insurance to protect me from other bone heads mistakes.
it will be tough going for you as I guess they'll just pay you out for a non-turbo silvia :mad: if you can try and buy the wreck so you can get the engine back (if it's ok).
on the bright side you still have your health! so booze on I say and start looking for a new car. :mad:
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
