Bang for buck : GTR > Ferrari
Probable superior track time: Ferrari > GTR
Chick pulling power: Pretty close. If you like the italian girls, get the pony, if you don't mind the asian persuasion, GTR is the car.
Either way, you'd get attention. And realistically, how many of either car will be driven anywhere near their potential? Most of them will be baubles or at most see a squirt on the freeway once in a while.
(Dubai and Germany excepted)
I think any chick prefers Ferrari over a Skyline :)
  • Replies 46
http://www.hamann-motorsport.de/galerie/Ferrari-599
whoever posted that.... O M G!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i love my cars, but that Ferrari has gone straight to the top. It's absolutely amazing, the finishing is just stunning. The epitome of tastefulness.
i was thinking black rims for my car, but without the silver lip... but after seeing this Ferrari....
my goodness...
I reckon the GTR looks too bulky (like most of the new Jap cars at the moment), at least the Ferrari has some sleekness to it. I like how the rear guards on the Ferarri slope in towards the mid section of the car making it look more muscular, whereas the GTR just looks overweight (just my opinion though..)
they both look ugly as sin.
the ferrari looks like a masserati of sorts... dunno.... looks more rich man undergoing midlife crisis masserati-esque than sporty ferrari.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
