  • Replies 83
i have been filling up on a wednesday morngin on my way to work for the last couple of months now it seems to stay steady until wednesday morning maybe around 9am im guessing, then it goes back up, here's hoping they dont change there trends tonight and i get ripped blind 2moro.
https://www.sau.com.au/forums/topic/147970-price-rise/#findComment-2762112
Most servos i've seen around leave it steady till wed. In the mornin its nice n "cheap" then on the drive home wam bam thank u ma'am 10 or so cents more. Even if it is $5 or so a tank thats still a beer in my belly and not in some rich knobs pocket
https://www.sau.com.au/forums/topic/147970-price-rise/#findComment-2762127
They said the price will go up because they said that there will be a fuel shortage, so what do I see when I go to get petrol? Every man and his dog at the servo filling up their cars/4wd's/jerry can's left right and centre, thereby causing a fuel shortage....
https://www.sau.com.au/forums/topic/147970-price-rise/#findComment-2764661
kessels rd seems to be the cheapest on the southside
107-109 ish the last couple weeks, which is good when i fill up there with racing =)
also, i find fuel prices to be a slight annoyance if anything, it's the price i factor in with owning a car and not going insane
if you really hate the fuel prices that much, take public transport for a few years, then you'll have the right to whinge and moan
https://www.sau.com.au/forums/topic/147970-price-rise/#findComment-2766401
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
