  • Replies 2.1k
Posted Images
Or they could just fuel him slightly less so that he qualifies slightly higher (5-8 instead of 8-12) so that he has better track position in the first stint because it's easier to hold someone up behind you than it is to overtake someone doing a similar lap time.
yeah good point. but i think the problem with that he may not actually qualify better than that with the same car and setup.
team stratergy will work out. it will fall into place at some stage. Almost did in canada.
Quoted from greman newspaper and translated into english...
Sounds like a typical Joe Saward piece of bullsh!t. He basically makes up whatever he wants & reports his opinion as fact or occasionally as conjecture. More often than not he is completely wrong.
As the quote goes "Writing fiction is great, you can make up just about anything."
He is one reason why I never used to buy Motorsport News. Although now you don't have to pay for it.
It does explain to some extent whay we havent seen any sort of aero upgrades recently... Mclaren, BMW, Williams even Honda have introduced parts recently. You'd think Ferrari would be right up there pumping out aero pieces to keep up with Mclarens rate of development, but no. This week is the first week in some time that they're adding new aero parts on the car.
Just seemed like a logical explanation...
Well it's plausable. Which is the kindest thing you can say about some of his stuff.
Unfortunately for peeps like me Ferrari are dropping the ball in many areas this year and it starting to show up now the season is getting serious. I know of maybe a big aero upgrading coming but not until August which is way to late in the year. I think maybe some of those key members leaving is starting to filter through
Im with you there, typical Mclaren, more data for Dennis's mob. Calling Honda a 'B' team is a complement going on there discraceful performance this year...maybe the 'Z' team would be better.
Well it isn't actually Ron Dennis' fault. More of a case of getting a deal done whilst he cane & whilst it can benefit McLaren. The rule shouldn't have changed - each entry should be required to use a different constructor. Back in the day companies such as Lola & March supplied heaps of chassis.
& yep Honda suck wang this year. Hopefully they will improve.
Lewis Hamilton stacked his Vodafone go kart at an event today!!
ahaha, lets hope thats the only wipeout he has this year!! it was a total noob mistake! :laughing-smiley-014: :laughing-smiley-014:
check it, helmet cam style. :D:)
http://www.youtube.com/watch?v=K_4uhYoMEX0
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
